05-28-2021, 08:03 AM | #1 |
Replace pulley when switching to electric fan?
We are working on the LY6 that’s going into my son’s ‘64, and I just had a thought. I removed the mechanical fan from the water pump pulley (that was an adventure!), and we are planning on electric fans for a bit of extra clearance. I have searched this a bunch of different ways, but can’t find a good answer... Do I need to swap the water pump pulley out, or is it good to go? I’m not sure if the nut between the fan clutch and the pulley is what retains the pulley, or if it is secured some other way. I obviously don’t want the pulley to come flying off while the engine is running. That would make for a bad day. Thanks for sharing your experience!
Chris |
05-28-2021, 09:35 AM | #2 |
Re: Replace pulley when switching to electric fan?
Hey Chris
The water pump pulley is pressed on and is not removable without special tools. The pulley should be good to go as is. Scott
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
05-28-2021, 11:14 AM | #3 |
Perfect. Thanks Scott. One less thing running through my mind when we get to the first fire up.
05-28-2021, 04:39 PM | #4 |
If you really concerned you could get a newer water pump that didn't have a mechanical fan. But having said that I just looked at a 2010 6.2 water pump and it looks like the end of the pulley is threaded not the water pump shaft.
06-06-2021, 01:57 PM | #5 |
I agree, just run what you have.
I tore down a 2010 Tahoe with electric fans. The factory(presumed) water pump had the threaded snout for a clutch fan, even though it wasn't needed.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
06-06-2021, 02:55 PM | #6 |
Just a quick update on the fan removal. I picked up the only pulley holder tool that I could find locally. It had a hole for a 1/2” breaker bar, but I couldn’t manage to keep the little pins in the pulley while I beat on my pipe wrench with a 5 lb maul. I ended up cutting a slot in a 4’ length of iron pipe, and welded the tool into the pipe. That let me brace the pulley holder against the floor. A few snacks like I was mad at it, and I got it broken free. Now that I know that the pulley pressed on and not going anywhere, on to the rest of the engine tasks.
Last edited by Jackson's Dad 64 C10; 06-06-2021 at 02:55 PM. Reason: Spelling counts! |
06-08-2021, 02:58 PM | #7 | |
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
