Old 05-29-2021, 12:01 AM   #1
ron350
ron350's Avatar
Power steering hose question
I am going to replace the high pressure power steering hose in my 75 C10 truck and want to replace the low pressure hose while I am at it.
What is the advantage to using low pressure power steering hose over fuel injection rubber hose?
I have 3/8 inch fuel injection hose but will purchase some low pressure PS hose if needed.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 05-29-2021, 12:50 AM   #2
kwmech
Re: Power steering hose question
No difference really, they are both oil resistant and return pressure is only about 30-35 #. I'd do it if that's what I had around. I'd recommend a filter though
Old 05-29-2021, 11:00 AM   #3
Pontiac1976
Pontiac1976's Avatar
kwmech-
good call on all.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 05-29-2021, 11:02 AM   #4
ron350
ron350's Avatar
Thanks for the reply I did not know they made PS return kine filters.
