05-29-2021, 12:13 PM | #1 |
Rear brakes sticking or dragging when moving slow
Not sure why, but every now and then, my brakes stick when going slow.
The rear end is out of an 83-ish truck, 3/4 ton, 8 lug. If the brake adjuster is all the way in, it’s really free spinning. To get the shoes just touching the drums, the adjuster is half-way out. And, I have these marks on the shoes like it’s skipping or bouncing. The front has discs. I plan on eventually converting to disc on the rear.
1963 C20, small window, long bed 292, 4-speed |
05-29-2021, 01:05 PM | #2 |
At the body shop.
Re: Rear brakes sticking or dragging when moving slow
Soft flex new ?
If it is not it could be collapsed internally
" That didnt make it any newer " " Dont antique the equipment " |
05-29-2021, 01:24 PM | #3 |
Soft flex?
05-29-2021, 04:44 PM | #4 |
At the body shop.
Flex hose between the frame and axle
05-29-2021, 05:03 PM | #5 |
05-29-2021, 11:14 PM | #6 |
At the body shop.
Our 68 broke this blue spring and they over adjusted til they locked up.
06-25-2021, 05:46 PM | #7 |
Fabricate till you "puke"
Just anouther thought....the rear diff is from a later truck? Maybe it has to do with piston size on the the brakes @ the rear(wheel cyls)? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-25-2021, 07:13 PM | #8 |
Hey ASSHAT, any news? Imho aproper adj would probably cure your problem.
They appear to be a bit to tight. |
06-25-2021, 08:00 PM | #9 | |
I'm probably going to convert the rear end to discs, just haven't picked up the parts yet. I found a setup that will work, converting it to disc brakes; I could even use the ElDorado calipers and setup a parking brake.
