Old 05-31-2021, 05:05 PM   #1
19Suburban69
Help with initial start up
I’m installing 6.0 w/4L80 in my ‘69 C20 suburban. First time playing with LS. I’ve got most mechanicals done and it’s down to wiring and exhaust. I need to know if I can do initial start up with open headers. I’ll install O2 bungs in collectors and plug in sensors. If not I’ll have to trailer it 40 miles to and from exhaust shop, then go thru start up. I’m wiring challenged so I’m at a point I need to find someone to come over to guide me. I’ve got more questions, but I’ll stick with exhaust issue first.
1955 Chevy, 2 dr post, my first car
1969 Chevy C20 Suburban, 6.0 LS w/4L80
2001 Silverado Z71, 5.3 extended cab
19Suburban69 is offline   Reply With Quote
Old 05-31-2021, 06:08 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Help with initial start up
I ran mine with open headers....no issues...just make sure theres nothing behind them thatll melt
If you use a quality wiring kit, it's actually fairly simple...most all of it just plugs in..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-31-2021, 08:27 PM   #3
paul mora
Do it all the time. Just make sure you don’t have anything that will burn at the end of the exhaust. Don’t rush the starts up double check as much as you can. Every time I have a problem at start up is because I rushed and want to hear it run before the neighbors went to sleeped
Pulatoy
paul mora is offline   Reply With Quote
Old 05-31-2021, 09:06 PM   #4
19Suburban69
Thanks guys. Clearance at collector isn’t a problem. I’ve gone over engine connections. Powered fuel pump today to clear lines. Then found I had 5/16 instead of 3/8 AN fitting that connects fuel at rail. Another trip to parts store. Hoping to get computer flashed this week.
Old 05-31-2021, 10:58 PM   #5
LS short box
The cool thing about a LS swap if all the connectors are connected as they should be and the fuel pump turns on it will start and run very quickly. On my LS swaps on first start I don't add water. Engine oil, trans fluid and power steering fluid on first start. Just run it for a 30 seconds or so. Look for fuel line leaks. Look for vacuum leaks.
Once I'm happy I add trans fluid as needed. Add power steering fluid and turn the wheel back and forth to make the air is out of the system. Then add coolant and make sure there isn't any air in the heads. I look for check engine lights. I do have a scanner.
The tune may be off until you get the exhaust on. O2 sensors can be confused by open exhaust.
LS short box is offline   Reply With Quote
Old 06-01-2021, 09:03 AM   #6
clay68c10
clay68c10's Avatar
You can leave the O2s unplugged while the headers are open. It won't drop into closed loop and try to use bad data from them.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
