Aftermarket Oil Pressure Gauge Install ?
I would like to run a oil pressure gauge off the idiot light sender on my 71 C/20. It came with the base instrument cluster. I have the gauge. It has the flexible plastic pipe but I need the proper fitting to connect to the block. Suggestion on hookup ? Take sender to parts house ?
71 C-20 07 Magnum RT AWD |
Re: Aftermarket Oil Pressure Gauge Install ?
Your easiest bet is to go to an auto parts store and get the cheapest oil pressure gauge you can find. It should have the fittings you need. I also recommend getting the copper pressure line for the gauge. The plastic one an wear over time with age or just rubbing and break. It makes a huge mess.
#3 | |
![]() Join Date: Jan 2016
Amazon sells a steal braded line kit that uses AN fittings and is easier to route
Allstar Performance ALL46110-72 (72") Gauge Line Kit $32.00 |
![]() Join Date: Dec 2013
use both , keep the idiot light on the dash and add a gauge .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Brass fittings can be found at Ace hardware / Loews / home depot .
Thanks guys ! Grumpy that is exactly what I intended to do. I appreciate the time you took to post those pictures and dimensions..Jack
