Old 12-22-2003, 09:08 PM   #1
pissonNOS
senior member
pissonNOS's Avatar
window help
How do them side windows come out? i put them in 3 years ago but now i want to tint them and can remember how to get them out?
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 12-22-2003, 09:16 PM   #2
gunnersm8
short of disassembling the entire door, and ripping out the weather strip rendering it useless for all of eternity, im not sure(thats what I did)
gunnersm8 is offline   Reply With Quote
Old 12-22-2003, 09:20 PM   #3
pissonNOS
senior member
pissonNOS's Avatar
i mean getting the window out of the tracks
69 GMC bagged
Old 12-22-2003, 09:20 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
The wind wing or the door glass???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-22-2003, 09:23 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
That post just showed up humm I think you can cut the adhesive around the glass to get it outta the track. But you should be able to tint the glass with it in there... Unless your talking about getting the glass outta the door???
MEMBER #6377
Project "7DEUCE"
Old 12-22-2003, 09:29 PM   #6
gunnersm8
yeah, mine was rusted to the point where it just fell out, in fact it still falls out if i hit a hard bump
Old 12-22-2003, 09:42 PM   #7
jef5150
Inline 69
jef5150's Avatar
you dont have to remove them to tint,,just trim the top with the window up(so when you close the window it doesnt try to peel the tint off),,and when you do the bottom ,leave an x-tra 1/4 inch that you will push down between the felt and glass with the plastic squeezy, when you are getting the bubbles out,,,,,jeff
jef5150 is offline   Reply With Quote
Old 12-22-2003, 09:44 PM   #8
pissonNOS
senior member
pissonNOS's Avatar
i mean getting the actual window out of the door like how does it undo from whatever its called i cant think of the word, not the track but. or better yet how is the window held in place?
69 GMC bagged
Old 12-22-2003, 09:46 PM   #9
gunnersm8
if i remember correctly (note- i planned on replacing weather stripping, felts, etc) i had to take the wing window out, pull the door felt out, and slid the window out.
Old 12-22-2003, 09:47 PM   #10
pissonNOS
senior member
pissonNOS's Avatar
i know that but the window is not loose in there its connected somehow to something thats what im trying to figure out
69 GMC bagged
Old 12-22-2003, 09:51 PM   #11
gunnersm8
as i said before, mine fell right out of the track, which is riding in the regulator, i think you have to play with it until you get the wheels of the regulator thingy to come out of the track
Old 12-22-2003, 09:51 PM   #12
pissonNOS
senior member
pissonNOS's Avatar
REGULATOR thats what the damn things called, hell i might reach a thousand post on this thread haha
69 GMC bagged
Old 12-22-2003, 09:53 PM   #13
gunnersm8
yeah you have to screw with it until the wheels come out of it, up and down, hold your tongue out right, squint the left eye, stop, drink 2 beers cussing at it with your buddies, etc. thats what i did.
Old 12-22-2003, 09:54 PM   #14
bow-tie-bandit
Live life and be happy.
bow-tie-bandit's Avatar
Door vent window
1. Lower the window all the way
2. remove the door trim panel
3. remove the door lock knob
4. remove the screws which attach the vent window lower
assembly to the door panel
5. loosen the inner and outer panel screws which are accessable
through the hole to the rear of the lower vent pivot
6. slide the main glass to the rear, away from the vent window
7. turn the complete assembly 90 degrees and guide it up and
out of the door
8. installation is the reverse of the removal
Door window glass and regulator
1. lower the glass completely, remove the window regulator
handle and the door lock knob
2. remove the door armrest and trim panel
3. remove the door vent window (above)
4. slide the main window glass forward until the front roller
is in alignment with the notch in the sash channel. Disengage
the roller
5. push the window forward and tilt the front edge up until the
rear roller is disengaged
6. return the window glass to the level positionand withdraw it
from the door
7. if necessary, remove the mounting screws and withdraw the
regulator assemblythrough the lower opening in the door
8. prior to installation lube the regulator mechanism with chassis
grease
9. installation is the reverse of removal
Hope this helps.
bow-tie-bandit is offline   Reply With Quote
Old 12-22-2003, 09:57 PM   #15
gunnersm8
yeah thats the ticket. i like doing **** the hard way.
Old 12-22-2003, 10:11 PM   #16
jef5150
Inline 69
jef5150's Avatar
heres a cut away pic
Old 12-23-2003, 09:27 AM   #17
FRENCHBLUE72
PROJECT 7DEUCE
BOW TIE NICE DIRECTION'S ...
MEMBER #6377
Project "7DEUCE"
Old 12-23-2003, 02:59 PM   #18
67chevemall
67chevemall's Avatar
Bow Tie for Prez!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
