Old 06-02-2021, 11:51 AM   #1
Mapearso
Which Lug Nuts to Use for My Slot Mag Wheels?
I am going to put a set of Slot Mag wheels on my 1972 Cheyenne Super.
15x8.5 front. 15x10 rear
It’s a 2WD 5 lug truck.
I had a similar setup on a truck I sold a few years ago. I recall needing some sort of special acorn lug nuts for the slots.
If anyone can advise on specs, manufacturer and where to buy I would be grateful for the info.
Thanks in advance for the help : )
Mapearso is offline   Reply With Quote
Old 06-02-2021, 12:07 PM   #2
sick472
sick472's Avatar
Re: Which Lug Nuts to Use for My Slot Mag Wheels?
In my limited experience with aluminum slots/wheels, there are at least two types. One would be a universal fit and would incorporate a large washer that had the appropriate offset hole location for the lug pattern that you have. The lug holes in the wheel would be outwardly slotted somewhat. The other, that I know of, would be similar, but with a hole centered in the washer. Both would be determined by the washer outside diameter and or shaper, the hole location (centered or offset), the lug nut shank diameter, and the shank length...along with the stud thread size and length. The first pic shows the universal style (I am NOT suggesting this is what you need, just a visual example) and the second shows the non-universal style (once again, just a visual aid). As simple as "lug nut" sounds, there is quite a bit that has to be defined before selecting and making a purchase.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 06-02-2021, 12:10 PM   #3
Davidf
I think you will need a shank style lug nut (sometimes called mag seat).
Probably 1/2-20. Most of the shank lug nuts need a washer. There are different reaches, so make sure what you get does not reach past the thickness of the wheel but close to it. If too much reach, you will not be able to tighten the wheel to the hub as the nut will bottom out against the hub. Too short and you get less bite/engagement on the studs.
Davidf is offline   Reply With Quote
Old 06-02-2021, 03:10 PM   #4
Grumpy old man
Grumpy old man's Avatar
Your in LA , Take one wheel to your local wheel dealer and buy the right ones the first time .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 06-02-2021, 03:23 PM   #5
Davidf
LOL, but that is not in the spirit of DIY.
Old 06-02-2021, 03:28 PM   #6
Grumpy old man
Load wheel in wives trunk ... take wheel out of trunk at wheel store...pay for lugs ... drive home ... you did it yourself ...
Old 06-04-2021, 10:09 AM   #7
MikeB
MikeB's Avatar
That's too simple. Better to buy on Amazon, wait a few days, and then have to return.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
