Old 12-22-2003, 10:21 PM   #1
popdad
carb riser
just wondering if any of you have every put a wood carb sacer on I have a pal thats in to wood big time and said they will make one for me just wondering popdad
popdad is offline   Reply With Quote
Old 12-22-2003, 10:47 PM   #2
C-10volvo
C-10volvo's Avatar
spacers will give you more high end power, while cutting down in low end tourqe. they are usually not worth the time to install them.
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 12-23-2003, 12:50 AM   #3
jon_volk
theres no definate answer on whether a spacer will help or hurt you...its one of those things that have too many variables..theyre cheap enough that you just test diff sizes out and see what yeilds the best dyno/track run/driveability
83 Monte Carlo
92 Camaro
jon_volk is offline   Reply With Quote
Old 12-23-2003, 01:22 AM   #4
76bonanza
76bonanza's Avatar
Also on many engines you can build low end torque with a spacer also. A good rule is an open spacer will build high end and a divided spacer will build low. But it is trial and error. I have seen motors make very good numbers with a spacer and others do nothing. But since they are cheap and the install is so easy I say go for it.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 12-23-2003, 01:20 PM   #5
Prerunner1982
Prerunner1982's Avatar
crackajacka had a wooden spacer he tried..... think he sold it or is trying too... might talk to him, see what his did.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-24-2003, 12:23 AM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I installed a four swirl hole 1" spacer on mine. I noticed a increase in low in torque. I can cruise at 1200 RPMs (45 MPH) in OD not bog down. Before I added the spacer the torque was really bad that the engine would struggle. I saw an small increase in gas milage. I've had it for three years with no problems. Cheap enough to try.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
