Richmond 4+1 Amateur Install
I'm a youngish(35) solo hot rodder and learn everything through trial and error or online research. I have to stop work and go buy tools often. My truck had a 3 speed and I wanted more gears. I bought this Richmond 4+1 pulled from an old Corvette a couple years ago on craigslist for $1100, with hurst shift linkage and yoke. I just got around to installing it and it was not easy. Getting the truck up high enough was an adventure but once I had the old transmission off I realized the Richmond had more splines so I needed a new clutch. So I stalled a new flywheel and pressure plate for good measure. So FYI you can't install the transmission with the bellhousing on on a 67 C10 due to crossmember. So I took it back apart and installed the bellhousing separate. Aligning the transmission through the bellhousing and throwout bearing solo is not easy either. I did many things in the wrong order and had to take things apart to access a bolt I needed on the next step. I also had to cut a new hole in the floor for the shifter and remove the transmission and re cut multiple times to get it right. Anyway working on these old trucks, esp mine, a frankentruck is always a puzzle. I put in a crossmember I ordered as well.
I was planning on posting a bunch of photos but am running to issues. These forums seem to only accept direct urls and the phone image hosting sites I'm trying are not giving me actual urls. Ug! I'll try again later. sry
67' C10 Flatbed Hot Rod Last edited by Phoax; 06-06-2021 at 03:30 AM. |
Re: Richmond 4+1 Amateur Install
Looking forward to the pics! Good luck on the project.
You can upload the pics as attachments. Select 'Go Advanced' and then 'manage attachments then 'upload'.
I got some pics. And another thing. I used a harbor freight transmission jack, pictured, worked great once I figured it out. It tilts one way. I had the transmission on backwards for the tilt I needed, had to lower and flip around. Jacked up once again I realized there wasn't any room to run the ratchet strap so I had to do a round 3 with no strap. I also got deluxe Hurst shift stick and and a large boot which just barely covers the hole for the old shifter. The pilot bushing was quite a job as well. Tried multiple pullers and ended up succeeding with a harbor freight one sculpted with a grinder to work.
67' C10 Flatbed Hot Rod |
Nice trans install, but your dash could use a haircut.
![]() Join Date: Dec 2013
Use bread to remove pilot bearings , I know it sounds crazy but it works and it's fast .
![]() https://www.youtube.com/watch?v=PunIehO_ch0
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Post Whore
![]() Join Date: Feb 2016
Did you check the alignment of the bellhousing to the crank shaft? If your not familiar with this operation there is lots of information on the interweb on how to do it.
Good luck with your new gear box. They are nice units. Unfortunately Richmond no longer supports them with parts.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Thanks for the replies. I hope to get my truck on the road this summer.
67' C10 Flatbed Hot Rod Last edited by Phoax; 06-12-2021 at 09:23 PM. |
#9 | |
Senior Moment
![]() Join Date: Mar 2002
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
#10 | |
I always used the grease method also. Instead of a socket I use a bolt that is close with electrical tape wrapped around it for a snug fit. I have only run into a few problem child's that needed a little more grease added. Always worked for me.
The original trans crossmember/mount was intended for the lighter/smaller 3spds w/bellhousing of the time. The larger heavier 4spd's (& now 5 or 6spds) & auto transmissions would utilize a more traditional crossmember @ the rear of the transmission like you installed.
With the new x-member in place, the original one isn't needed & can be cut out/discarded to make future service work easier. You can also make a patch piece for the original hole in the floor so that it covers the original hole w/about a 1" flange all around. Then open up a new smaller hole that works for the new set-up. That will help seal the floor up a little better. Fumes, noise, & external weather have a way of slipping past that style rubber boot when they barely cover the floor opening.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-22-2021 at 02:26 PM. |
