Old 06-06-2021, 09:03 PM   #1
CC69Rat
CC69Rat's Avatar
Flexplate question
67 C10, swapping in a 2004 6.0/4L80 combo. The engine is pretty healthy and I plan on running a stall converter. From what I hear, I will need to change the flexplate to run a stall (?) I've heard the LS1 flexplate will work ?
I understand the pump spacing and shimming I just want to make sure it's the right one for the starter etc. The one that came off the engine had a small crack at one of the bolt holes. I have to replace it some way.
Thanks.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 06-07-2021, 12:01 PM   #2
dayj1
Re: Flexplate question
You don't have to change the type of flexplate. You can stick with the 4l80 flexplate as long as you buy a converter with the stall speed you want that's made for an 4l80e. I suspect you're referring to what you see when folks swap from a 60e to an 80e and just have a converter made with the 60e bolt pattern to keep their existing flexplate.
dayj1 is offline   Reply With Quote
Old 06-07-2021, 04:48 PM   #3
LS short box
Contact one the stall converter folks and ask them about flex plates. I've only used 4L60E trans but use a SFI rated flex plates on my swaps.
LS short box is offline   Reply With Quote
