Old 06-07-2021, 01:15 PM   #1
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Need advise on wheels
I have a 61 suburban that im going to change up to 5x5 and im wanting to buy some supremes 15x7. I notice that summit racing has a few of them with different back spacing. does anyone know hoe much of a back spacing would I need to run in order to clear the calipers?
Sick5 is offline   Reply With Quote
Old 06-07-2021, 01:29 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Need advise on wheels
Pretty costly to take someone else word for it. By taking your own measurements you know for sure what you need. Your calipers and mine may be different etc.
Here's a link to a video (how to) and the form you can download - https://www.americanracing.com/wheel-measure-guide/
And another form - http://thewheelsmith.net/wp-content/...nt-Article.pdf
Old 06-07-2021, 01:37 PM   #3
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
thank you
don't we all just about run the same set up? 72-87 caliper are pretty much the same.
Old 06-08-2021, 03:59 PM   #4
forestb
forestb's Avatar
I had a set of 15X5 rallies with a standard back spacing. They fit on the CPP drop spindle. When I put them on the CPP modular drop spindle they no longer fit and I needed to add a .25" back spacer in order to get them to fit. when I say that they didn't fit I mean they actually did fit but they knocked off my clip on wheel waits but did not touch the rim. Hopefully this helps.
forestb is offline   Reply With Quote
Old 06-08-2021, 04:42 PM   #5
Southcity
Southcity's Avatar
This is very sound advise and not very difficult to do, and you will "know for sure what you need".
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 06-12-2021, 08:53 PM   #6
PGSigns
PGSigns's Avatar
A tool like this is really what you need. The tires you are going to run can make the back spacing you run different from that of others. A tire with a wider section width can push the wheel in or out depending on the truck. Only true way to get rims and tires that fit.
Jimmy
https://sdparts.com/i-21234610-percy..._content=Brand
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-18-2021, 01:49 PM   #7
SCOTI
SCOTI's Avatar
Every vehicle is different. Combos utilizing the same/similar parts but on a different vehicle can/often does yield different results truck to truck.
Find a cheap 7" 5x5 OE wheel (or borrow one) to get an idea of fit. Once you have a visual, you can make a decision on back-spacing changes & the impact more or less might have for your set-up. Or . . ..... Buy one of those back-space measuring tools.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-19-2021, 01:21 PM   #8
61K10
61K10's Avatar
most after-market 15" rims will fit over the calipers------
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
