Old 12-23-2003, 12:10 AM   #1
chopper
? 66 Trans Swap 3 sp to Auto Need Help
I have a 66 C10 SWB Step side 6cyl 3 on the tree. Want to put in 350 Turbo. Found runing 68 LWB 3/4 ton 250cu in. w/350 w/long tail stock. Every thing there to make the swap. Being a long tailstock will there be any difficulty with this setup? Don't know if crossmember will fit the frame rails or e-brake will work.
Like to put the auto steering colume from 68 to 66 will this work ?
A 350 Trans short tailstock is also available. Need all the help I can get .
Thanks Chopper
Merry X-mas
chopper is offline   Reply With Quote
