06-12-2021, 01:10 PM | #1 |
Driveshaft Question
Okay, so I'm doing a "piece at a time" swap in my 68C10 from a 327SBC w/3spd manual with factory rear (truck) 12bolt to a 454BBC with 4L60E overdrive auto and (passenger car) 12bolt posi.
I'm hoping to do the trans swap first. I know that I'll need a new driveshaft. I need to know if, when done but still behind the SBC, will I then need a 2nd new driveshaft when converting to BBC...or put another way... Is there any difference whatsoever in trans bellhousing (horizontal) locations between SBC and BBC ? and then is there any difference between 12bolt (truck) and 12bolt (car) nose lengths ? Last edited by john68c10; 06-12-2021 at 01:26 PM. |
06-12-2021, 04:40 PM | #2 |
Re: Driveshaft Question
Yes. If you use the factory big block stands for the big block conversion it will push the transmission back 1'' from the small block position
06-12-2021, 04:45 PM | #3 |
