Old 12-23-2003, 12:28 AM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
465 to 205 adapter for sale
This is an adapter out of a 72 Chevy pickup. There are no moving parts except the seal, which need to be replaced. One of the bolts that holds this to the cross member broke off. I drilled it out so the threads are a little rough on the bottom. The threads are also an inch deep, so I don't think it will hurt anything.
I also have the sleave for sale. It is a little worn on the transmission end, so you might get a little play, but not bad.
I don't know what these are worth.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 12-23-2003, 12:29 AM   #2
Scrub
Scrub's Avatar
Collar
Scrub
