Old 06-13-2021, 10:04 PM   #1
lkt1954
69 Fuel Lines
I'm building a 69 GMC short wide bed truck with a 350 and sniper EFI.
Also I'm relocating the fuel tank to the frame in the rear.
My question is what year model fuel lines to run from the front to rear?
I would prefer to stay with OEM lines if possible.
lkt1954 is offline   Reply With Quote
Old 06-14-2021, 02:53 AM   #2
BigBird05
Re: 69 Fuel Lines
When I moved my tank to the rear I just made my own lines. Since your running fuel inj, your going to need a larger fuel line then stock plus a larger return line.
BigBird05 is offline   Reply With Quote
Old 06-15-2021, 01:19 PM   #3
lkt1954
Re: 69 Fuel Lines
I was thinking more along the line of using pre-bent lines from a year model that had a rear tank and changing out the fittings.
Holley says in need a 3/8" line for both.
Would 2 fuel lines (3/8") for a 72 model work?
Old 06-21-2021, 02:02 PM   #4
lkt1954
Re: 69 Fuel Lines
Bump
Old 06-21-2021, 03:04 PM   #5
Jason Banks
Jason Banks's Avatar
Re: 69 Fuel Lines
If you must use pre-bent lines. I would say your best bet it to call Inline Tube and see if they can offer any help.
For my LS Swap with Boyds tank. I made my own lines using 3/8 aluminum tubing from Summit:
https://www.summitracing.com/parts/sum-g2538
Fairly inexpensive for the tubing, but the AN fittings and hoses, probably added another $100
The aluminum tubing is so much easier than even the Nickle Copper. With the aluminum you can basically manipulate it with no tools. I did use a bender for some areas where I wanted a 90.
I used these clamps to attach the tubing inside the frame rail:
https://www.summitracing.com/parts/nth-1616-6
I basically cut the 25ft roll in half and got both pieces fished into the frame rail. Started at the back where the tank is and put 2 clamps, then just worked my way to the front installing clamps in a uniform fashion.
Jason Banks is offline   Reply With Quote
Old 06-21-2021, 07:47 PM   #6
lkt1954
Re: 69 Fuel Lines
Thanks. Inline tube suggested the same thing- build your own.
Old 06-21-2021, 08:08 PM   #7
gt40racing
gt40racing's Avatar
Re: 69 Fuel Lines
What fittings did you use on the aluminum lines? I think I will try this on my 69.
1989 5.0 LX Coupe
1989 Saleen #243
1969 C-10 Fleetside
1966 Mustang Coupe GT
1965 Fastback Mustang
1951 F1 Truck
gt40racing is offline   Reply With Quote
Old 06-21-2021, 08:31 PM   #8
Jason Banks
Re: 69 Fuel Lines
I used these to attach to the tubing:
https://www.summitracing.com/parts/sum-2200075b
https://www.summitracing.com/parts/sum-2200077b
Using the above will not require a 37° flaring tool, which is not common.
I bought a flaring tool for some reason, thinking I was going to use the tube nut/sleeve combo like these:
https://www.summitracing.com/parts/sum-220633-2b
https://www.summitracing.com/parts/sum-220634-2b
With the tube nut and sleeve, you put the nut then sleeve on the tube and flare the tubing and you can then connect to a male AN fitting.
Old 06-21-2021, 10:02 PM   #9
gt40racing
gt40racing's Avatar
Re: 69 Fuel Lines
Thank You!!
1989 5.0 LX Coupe
1989 Saleen #243
1969 C-10 Fleetside
1951 F1 Truck
Old 06-21-2021, 10:04 PM   #10
gt40racing
gt40racing's Avatar
Re: 69 Fuel Lines
I picked up a Rigid 37° flaring tool when I was working on my F-1. Great tool for this application.
1989 5.0 LX Coupe
1989 Saleen #243
1969 C-10 Fleetside
1951 F1 Truck
