Old 12-23-2003, 12:47 AM   #1
wyoridgerunner
Does a 208C2 transfer case interchange with a 208C3 ?
Does anyone know whether a 208C2 transfer case and a 208C3 will interchange. The C2 is from a Turbo 350 & I think the C3 is from a Turbo 400, both are 1985 & the same ratio. The problem is I do not have the C3 in hand so that I can compare them. Thank you wyoridgerunner
wyoridgerunner is offline   Reply With Quote
Old 12-23-2003, 05:42 PM   #2
RockHQ
ROCKET POWER!
RockHQ's Avatar
X-fer case input shafts might have different lenghts&spline counts, other than that since they're both 208C's they should interchange. Now since i've not had the opportunity to compare these two i cannot say for sure, however even if the input shafts differ you should be able to interchange them. Anyone have experience with this?
g'luck,
-Axle
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 12-23-2003, 08:55 PM   #3
wyoridgerunner
Thanks for the reply. I will check it out. appreciate the info. Ridgerunner
