Old 06-14-2021, 09:21 PM   #1
CanadianK20
CanadianK20's Avatar
Fuse Size
What size fuse are guys installing in the main power link before the junction box?
CanadianK20 is offline   Reply With Quote
Old 06-15-2021, 10:15 AM   #2
prodjay10
Re: Fuse Size
you talking about the fusible link?
prodjay10 is offline   Reply With Quote
Old 06-15-2021, 10:41 AM   #3
CanadianK20
Re: Fuse Size
Yes. It’s on the main power feed just before the junction terminal.
Old 06-15-2021, 11:46 AM   #4
67ChevroletDude
67ChevroletDude's Avatar
Re: Fuse Size
When I redid my wiring on my 67' I believe I used a 40 amp MAXI fuse on an 8awg wire to my power bus
67ChevroletDude is offline   Reply With Quote
Old 06-15-2021, 12:37 PM   #5
sick472
sick472's Avatar
Re: Fuse Size
Try this...
http://67-72chevytrucks.com/vboard/s...t=fusable+link
and this...
http://67-72chevytrucks.com/vboard/s...d.php?t=433539
I used the 16 gage fusible link that was 8 inches long on my 72 based on the above threads. So far so good!
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 06-15-2021, 01:45 PM   #6
Hunter757
Hunter757's Avatar
Re: Fuse Size
You should have 2 the factory fuse that can be replaced (4A) SFE glass fuse. This is what came from the factory. They inside the little black plastic tube.
Hunter757 is offline   Reply With Quote
