06-15-2021, 04:15 PM | #1 |
Need help on C10 454 swap
I'm swapping a 454 from a 1986 3/4 ton 2wd suburban to a 1986 C10 short bed, I'm using all of the original 454 parts such as frame stands, motor mounts and engine clam shells. Today, I removed all of the mounts from the C10 and placed the 454 stands on the frame. I can get the 2 bolts that mount the stand to the top of the frame in, but the 2 holes on the crossmember are an inch too low, this is the same for both sides. The frame stands had about 1/2 inch front to back adjustment on the "burb", but nothing when mounted to the C10. Is this going to cause any issues? Do I bolt in the top on both frame stands and drill the two lower holes? I was expecting the frame to be double drilled at the factory and the stands would drop right in. Thanks!
06-15-2021, 08:51 PM | #2 |
Re: Need help on C10 454 swap
Here's the 454 mounts.
06-16-2021, 09:57 AM | #3 |
3/3 ton frames are taller and the stands do not directly swap between the frames. Yes, you will need the stands bolted down properly to prevent movement and part breakage. Correct stands or break out the welder.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
06-16-2021, 10:05 AM | #4 |
If I'm not mistaken you could have just used the original stands as I don't think it really changes the position of the engine in the square bodies
06-16-2021, 08:21 PM | #5 |
I was going to that, but was told the engine would sit about an inch lower, which would cause problems if I go to headers. I did compare the sbc against the 454 frame stands, and they are different in height, about an inch. Anyways, I used the holes on top of the frame as a starting point and got the engine in today. I'll pull it back out and drill new holes for the bottom bolts, I have the core support out, so fairly easy to pull and replace the engine.
06-17-2021, 09:30 AM | #6 |
The big block is in.
06-18-2021, 02:10 PM | #7 |
Nothing to it but to do it
06-18-2021, 04:06 PM | #8 |
I know my way around the GM "A" body cars, because that's what I grew up with, I just don't have much wrenching experience on pickups. It turned out to be a straight forward swap, but I got derailed by some misinformation on the web. Imagine that! Anyways, It's an unfinished project that I'm getting to start, run and stop, and then sell. It came with a trans crossmember that just attaches to the bottom rail, but it fits and will work good, only have to drill a couple of holes. I was hoping to use the smog manifolds, but no way are they going to fit unless I remove the tubes or raise the engine, going to order headers tonight.
06-21-2021, 08:23 PM | #9 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 |
06-21-2021, 08:59 PM | #10 |
The swap is all done, working on getting it wired up now. I used all the big block mounts, frame stands clam shells etc... which sat the engine about an inch higher than the original small block parts would have. I had it for sale on FB as an EZ project, but no bites, so I'm going to get it running and drive it this year. Still have to get the correct slip yoke, driveshaft cut, grille, new tires, exhaust and whatever it needs to pass inspection. Thanks for the replies!
06-22-2021, 09:42 AM | #11 | |
06-22-2021, 10:23 AM | #12 |
Yeah, it's getting tougher to sell a running or roller project, the people with $$ to spend would just as soon buy a turn key/done car. I'll have it running this Week, but it still needs everything to be a show truck. There seems to be a shortage of "hands on" car guys, when I was young (1970's) 9 out of 10 us teenage boys were putting something together, that's not the case today. I just retired and have sold most of my stuff and want to go fishing, otherwise I'd build this for myself.
06-22-2021, 10:42 AM | #13 | |
