Old 12-23-2003, 01:06 AM   #1
krue
Designated A-hole!
krue's Avatar
Thumbs down Uh-oh!
I go to drive home from my folks and everything electrical on my truck flickers including the engine. Happened two or three times in first 5 or 10 miles then stops. What do I need to be checking? The battery cables are clean and tight.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-23-2003, 01:47 AM   #2
racedvl
racedvl's Avatar
Are you externally regulated? I have had regulators do that to me. Time for a internal conversion. . . .
racedvl is offline   Reply With Quote
Old 12-23-2003, 01:55 AM   #3
krue
Designated A-hole!
krue's Avatar
That's what I am thinking. The timing could be a little better tho!
www.daveramsey.com
Old 12-23-2003, 05:05 AM   #4
ZOOMY
flicker
Make sure the wires are tight at the fender terminal by the battery.
ZOOMY is offline   Reply With Quote
Old 12-23-2003, 11:14 AM   #5
Huck
Huck's Avatar
Check the negative ground from the battery to the block--block to the firewall.
Huck is offline   Reply With Quote
Old 12-23-2003, 11:33 AM   #6
Randy70C-10
Randy70C-10's Avatar
Make sure that your alternator bracket bolts are tight.
Randy70C-10 is offline   Reply With Quote
Old 12-23-2003, 12:28 PM   #7
krue
Designated A-hole!
krue's Avatar
All cables and brackets are good and tight. How do I test the regulator?
www.daveramsey.com
Old 12-23-2003, 01:02 PM   #8
Randy70C-10
They are so cheap that I never test them. I just replace, and if it doesn't fix the problem then I know that wasn't it.
