Old 06-16-2021, 11:59 AM   #1
tdangle
tdangle's Avatar
Prothane Motor Mounts
Thinking of trying these as I'm not real comfortable with the stock ones and possible breakage. Do they noticeably transmit more engine vibration than the stock ones? Also anyone have a part number for the trans mount?
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 06-16-2021, 01:00 PM   #2
gmc684x4
Re: Prothane Motor Mounts
I can not say how much vibration they transmit I have a set for my build and a set of new aftermarket rubber ones
I have less faith in new rubber ones then I do with factory gm that are in good shape I think the quality in material is not there
gmc684x4 is offline   Reply With Quote
Old 06-16-2021, 01:33 PM   #3
NorCalC20LWB
Have them on mine, both engine and tranny mounts. You can definitely feel more of a "rumble", but I like that, a bit less refined. It is not radically different though. Plus, when I removed the old rubber tranny mount it was torn in two pieces, so a definite plus in strength. Mildly built 350/350 C20.
NorCalC20LWB is offline   Reply With Quote
Old 06-16-2021, 04:45 PM   #4
Big Kev-O
Big Kev-O's Avatar
I installed new rubber mounts a few years ago along wit a mild 350 SBC. Just noticed the driver side was cracked pretty bad. Might have something to due with my burnout habit, having an empty parking lot during the pandemic is too tempting to resist. I replaced them with some Prothane 7-509 mounts. I'm using the Energy 3.1108R mount on the transmission. I didn't notice any significant change. Truck seems a bit snappier on launch but could be my imagination. I read the center bolt style like I have is more prone to failure than the clamshell style.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 06-16-2021, 05:13 PM   #5
MySons68C20
MySons68C20's Avatar
Have the Prothane mounts and very happy.....I concur with NorCal's comment. Buy them!
MySons68C20 is offline   Reply With Quote
Old 06-22-2021, 03:19 AM   #6
tj1970cst
I have them, didn't notice a difference. My wife hates the combo of the mounts and the cam.
tj1970cst is offline   Reply With Quote
Old 06-22-2021, 03:39 AM   #7
Richard
Purchased a pair of the Prothane big block/4x4 mounts. Cannot use them due to my motor change. I can list them if you are interested.
Richard
Old 06-22-2021, 11:01 PM   #8
jimijam00
I threw away a prothane trans mount because the urethane was not level on top. It was almost 1/4" higher on one side.
jimijam00 is offline   Reply With Quote
