Old 06-16-2021, 04:11 PM   #1
kglowacky
rack and pinion
anyone upgraded to a rack and pinion set up in your truck. If so what type and Results?? Thanks
kglowacky is online now   Reply With Quote
Old 06-22-2021, 01:28 PM   #2
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: rack and pinion
I used No Limit's conversion kit, but had to swap to an aftermarket lower A-Arm as the stock bushing is too big and does not allow the rack to sit in the correct location.
With that said, it was a great upgrade. Steering was more precise and with the increased cast the new arms provided, it was much nicer to drive.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-22-2021, 02:49 PM   #3
kglowacky
Re: rack and pinion
looks like from there web page their kit only fits up to 1972. I have a 1978
Old 06-23-2021, 08:57 AM   #4
TrybalRage
Re: rack and pinion
This is something I've considered trying to do. The conversion kits are rather expensive (~$1k) and I wonder how hard it would be to fab up some brackets to run a rack off a newer truck or some other vehicle.
1985 C10 Silverado LWB LS Swapped! Other Stuff
2010 Suburban 2500 LT 4WD
TrybalRage is offline   Reply With Quote
Old 06-23-2021, 01:09 PM   #5
aggie91
aggie91's Avatar
Re: rack and pinion
This is true about their web site. BUT, I installed it on an '82. I just had to swap lower control arms to an aftermarket set that used a smaller diameter pivot bushing where is mounts to the cross member. Arms from CPP, Ride Tech, Porter Built (I used PB's forward arms to increase caster) will all work well with No Limits rack conversion. Only other change I had to do was with the support bearing for the steering shaft. Look through my Sunburn thread in my signature for pictures...Post #258, #266, #289, #291, #294, #298
Karl
The LST Challenge:
Last edited by aggie91; 06-23-2021 at 01:13 PM. Reason: added post numbers for reference pictures
