Issues adjusting carb
I apologize for asking this as I know it's been asked on here a million times already. I did do some research and tried some things based on what I read, but I'm still having issues.
It seems the engine will only run with the choke in the 40-70% open range (approx). If I close the choke completely, the engine dies. If I open the choke all the way, the engine dies. As I open from 40% to 70% the RPMs go up and seem to max around 60% open. As suggested on other posts I've sprayed carb cleaner around the carb while running and didn't detect any vacuum leaks. I also started w/ the mix screw at 2 turns out and slowly backed it out a half turn at a time but nothing I did stopped the engine from dying as soon as the choke was opened all the way. Thanks in advance for any assistance you can provide.
Brian '69 GMC C15 Inline 6, 230ci (possibly 250ci) |
