Old 12-23-2003, 01:23 AM   #1
crossy
Oh,you can't buy that new
crossy's Avatar
headers for lowered trucks. what works?
Since the headers on this 81 are mangled on the bottom beyond repair I have decided to replace them. I thought someone here had said that Chevelle headers work and sit up higher ? has anyone really tried this ?
I need full length headers not shortys.
any recommendations thanx , DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
84,C10 SWB-Yella,stock
86 K10 SWB-Red, hopped up 305,4/S
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 12-23-2003, 01:25 AM   #2
r0lf-
Hotwheels?
r0lf-'s Avatar
My thorleys are full length and have no clearance problems whatsoever, Ive never scraped them once.
4/6 too.
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 12-23-2003, 02:10 AM   #3
TIMSPEED
TIMSPEED's Avatar
4/6 too.
How much them thorley's run? Low84 has a set of Chevelle headers that work for a 5/7 drop...I think they're the 73-87 G-body headers...
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 12-23-2003, 02:20 AM   #4
78chevstepside
78chevstepside's Avatar
I have hedmen full length headers with a 4/6 drop. I dont have any problem with clearance or bottoming out.
78chevstepside is offline   Reply With Quote
Old 12-23-2003, 02:33 AM   #5
ocbaud
Garage Queen Material
i hit my header collectors all the time with my truck and a 4/6 drop. i have hedman full lenghts too.
ocbaud is offline   Reply With Quote
Old 12-23-2003, 03:04 AM   #6
r0lf-
Hotwheels?
r0lf-'s Avatar
Dang... its been a while. They arent cheap, thats for sure. I want to say 250 or so.
Old 12-23-2003, 03:24 AM   #7
stepside454
stepside454's Avatar
the Cyclone full lengths that were on my lowered truck when I bought were scrappin all the time. with a big block I couldnt find much to choose from. I bought Sanderson Shortys.
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 12-23-2003, 08:52 AM   #8
bigblock73
yeller
bigblock73's Avatar
Hooker Competition full length headers on a 4/4 dropped SBC equipped truck...never hit once in 4 years of driving.
bigblock73 is offline   Reply With Quote
Old 12-23-2003, 10:40 AM   #9
SCOTI
SCOTI's Avatar
Last time I check prices on Thorleys they were $400+. The chevelle 3/4 length from Headman or Hooker will work & be cheaper. The downside is Thorleys are a 2 into 1 configuration so you gain torque over the un-equal length of the 3/4 style.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-23-2003, 11:52 AM   #10
TwinTurbo
TwinTurbo's Avatar
Hookers here and they scrape like mad
TwinTurbo is offline   Reply With Quote
Old 12-23-2003, 12:30 PM   #11
crossy
crossy's Avatar
with the 4-6 (or 5-7, not sure) drop thats on this truck it doesn't even have collectors anymore. they are hedmen full lengths.
Timspeed- when you say 'G' body you actually meant 78-88 body style right?? the 73-77 chevelle was still called an 'A' body I believe. I know all the major header manuf. list the 78-88 seperately.
More importantly can anyone verify that this 78-88 header works out??
I need to get these collectors up . there is a good 4" of clearance between them and the floor now so i know i have room to bring them up. Even without the collectors they give me trouble on my trailer ramps. thanx for all the input guys keep it coming. DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 12-23-2003, 03:26 PM   #12
78chevstepside
I have a 4/6 drop(maybe not) with hedmen full length. I have about 4" of clearance. I dont go over speed bumps very fast . Or go up sloped driveways very fast . One thing I did was rotate the flange so I have the most possible clearance. I also have headerhush power flanges or flange stifners to keep from tearing up the weak flanges.
Old 12-23-2003, 03:45 PM   #13
low 84
low 84's Avatar
the headers i'm using that timspeed is talking about are for late 60's early 70's camaros and chevelles. they are NOT full length. if you try to use a full length car header on your truck the collectors are most likeley going to shoot straight into the tranny crossmember. this is what matt (82 blackbeast) did on his truck. he then had to build a custom tranny cross member to clear the headers as well as clearence the frame for the large diameter camaro full lengths he is using. if you really think you need full lengths and go the car header route you are just going to have to shoot in the dark and mabey you will get lucky. the short headers i'm using WILL fit with no modifications. the are very small primary tubes and 2-1/2 collectors, but will work fine for anything producing less than about 350 hp. they are really choking my 408, but i had planned to go the same route as matt if i wasn't going back to a stock motor. i've listed the part number for my headers before but i don't have it handy right now, just do a search if you want it.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 12-23-2003, 03:54 PM   #14
ocbaud
thats about 3.5" of clearance
Old 12-23-2003, 04:21 PM   #15
78chevstepside
I didnt find that a problem the crossmember being in the way. I just went right over the top. I made my own exhaust system. I guess if a guy doesnt own a welding machine this would be a big problem. I dont own a tubing bender neither. iIjust make minor cuts and weld it all together. this does hurt your flow having restriction in your pipe. I run 2.5" exhaust system its plenty big (sbc) to make up for any losses. I can weld alot better then them guys down at the muffler shop. A guy could just as easy make his own dual crossmember.
Old 12-23-2003, 05:12 PM   #16
crossy
crossy's Avatar
. they are really choking my 408, but i had planned to go the same route as matt if i wasn't going back to a stock motor. i've listed the part number for my headers before but i don't have it handy right now, just do a search if you want it. [/B][/QUOTE]
I'm not going to choke mine down. what I'm trying to find out is what full size car application did 82 blackbeast use . I most likely will not have the crossmember problems because mine is way back with the 400 trans. I can also build my own x-member if needed. thanx , DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 12-23-2003, 08:24 PM   #17
AirMale
AirMale's Avatar
I can't speak for trucks with small blocks anymore. The headers I have now are hooker #2455 and they tuck up between the framerails. I also use a double-hump crossmember and it works great. If I were you Dave I would order the Hooker #2451 from summit and if you had any trouble with fitment just send them back and eat the shipping...no biggy! They should fit between the framerails. Good luck!
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 12-23-2003, 08:52 PM   #18
crossy
crossy's Avatar
Originally posted by Riptide's 78p/u
i knew these pics might come in handy Power Flow headers (full length)
man my truck would not only take off the collectors but the whole headpipe on those. LOL.
Jay , sure rub in the big block thing now. I really wanted to get together with you and your other truck buds over the holidays ,but it looks as if it's going to be a while now because of the royal F@^#%ng this A-hole gave me on this truck. I WILL prevail, but there are SO MANY jury rigs(the headers just being one of MANY!) on this truck it will most likely be spring before i can come see ya. I know there are a lot of swap/cruises your way and I shall get there,but in the mean time if you are ever headed to the track be sure to let me know , DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 12-23-2003, 09:44 PM   #19
1FaastC10
1FaastC10's Avatar
67-69 Heddman Hussler's 1 3/4" primary, 3" collector. he's running a pretty hot 383 though, so he needs the 1 3/4" headers. if you were going to put them on a mild small block, you would kill any chance of having anything that resembles low end torque.
1FaastC10 is offline   Reply With Quote
Old 12-24-2003, 02:49 AM   #20
low 84
low 84's Avatar
jeremy nailed it, those are the ones matt is using but they are too big for anything less than 400-450 hp. i think matts 406 is making over 500 so thats why he used them. with some 1-5/8 headers the frame rails might not need clearencing like he had to do on his.
'05 1500 Crew Cab
RIP
Old 12-24-2003, 02:58 AM   #21
ocbaud
ryan, would those shorties you have handle <400hp pretty well?
Old 12-24-2003, 03:02 AM   #22
crossy
crossy's Avatar
the ruined headers on it now are husslers( i found the tag). Yes 1-5/8 is the minimum I will take as it does have the 1-3/4 now and yes it is ,and always will be, in the 450-up range for HP. DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 01-02-2004, 03:36 AM   #23
1972C10
1972C10's Avatar
GEt some flowtechs for 88-98 the direct fit you will have to get pipes run to them with the flare type flange but they are a real good shorty style header with 3/8 thick flange.
1972C10 is offline   Reply With Quote
