![]() Join Date: Jul 2017
Aftermarket aluminum radiator, fan and shroud kits
I'm at the point of needing to buy a radiator for our project. It's gonna be 1970 C20 with a massaged 350, Tremec 5 speed, a/c, p/s, p/b, which will be used as a daily driver, plus pulling a racecar on an open trailer on race weekends.
What radiator/fan/shroud kits have you guys bought, and why should I buy the same or stay away from? |
Re: Aftermarket aluminum radiator, fan and shroud kits
Don't fall for that "4 rows is better" routine. Get you a two row with at least 1" tubes. I've got one 16" spal fan with a shroud sucking through a EPC found here https://speedcooling.com/1967_1972_C..._Radiator.html
Another good option is the CC found here https://www.coldcaseradiators.com/pr...case-radiators Dewitts makes a nice rad, but is WAY WAY overpriced. I've had no problems with the Champions in the past on other vehicles. |
Who Changed This?
![]() Join Date: Jan 2013
Run what you have until you see what it does, is my recommendation. These trucks were rated to pull the weight and keep cool. Never mind that I have a Cold Case aluminum radiator, a larger fan and custom shroud and a severe duty fan clutch. I was chasing a gremlin that ended up being flow, which a simple high-flow thermostat took care of.
Cold case is ok . I have one ready to go for my 72 but I bought it at the Syracuse nationals from them so it was only $250 fans , wiring and shroud no shipping . But I never put it in as the copper rad keeps it nice and cool
Dewitts aren’t overpriced in my opinion . I have one in my 66 SS Chevelle over 5 years it replaced a champion that lasted 4 weeks . Leaked at the seam they sent another and it leaked from the get go . The Dewitt fit perfectly unlike the champion that needed mounting holes elongated to fit ,minor issue but shouldn’t have to modify a new radiator. There is no comparison in quality between the 3 the Dewitt wins hands down Dewitts are American made in Michigan .
