06-19-2021, 04:21 PM | #1 |
How would you rate these hood hinges?
I received a set of new hood hinges today. I won’t mention the vendor as I’ve sent them a message and want to give them time to respond. But, I wanted to get your thoughts on them in case I’m expecting too much. They were described as “Hood hinge, exactly like original. Highest quality available.” So if this is normal, I’ll give them a shot…but they don’t look or feel better than the bad originals I removed on the surface. Maybe they would shine when installed.
Issues: The right hand hinge had an elongated hole where one of the rivets goes. This appears to be a guaranteed “slop” point once things get worked over time. The other holes seemed circular like I would expect. Otherwise the mechanism is tight, currently. My concern is long term with it. The left hand hinge was very easy to move out of the box. If I hold the fender side tightly, I can get the hood mounting flange to move or twist left/right maybe 1/8-1/4” with the arm allowing it (like the rivets are not tight). If I hold the whole hinge assembly in the air, I can make it chatter almost like a tambourine. I try to show that looseness in the pictures. Look at the top right corner of the photos at that part of the hinge. Use the background as reference to see it moving. The hinge with the slotted hole does not chatter. Are these concerns valid or normal/ok? I do know they will behave differently with springs and a hood on it, too. I paid a little more for them vs AMD and others to try to get the best aftermarket I could. And please, before you tell me….yes, I know I can look for originals in decent shape or have originals rebuild. UPDATE: Vendor contacted me back. They said all their RH hinges have the rivet/slot that way. They’re not sure why, but have had no issues with them. On the left side, I was told that when installed with springs, there will be no issues with things seeming loose. I’m tempted to give them a shot, but looking at the loose one, the area it is loose would not be affected by the spring. It would still have the same movement. Thanks. Last edited by General23cmp; 06-19-2021 at 05:42 PM. Reason: New info |
06-19-2021, 08:00 PM | #2 |
Re: How would you rate these hood hinges?
hi, I bought two good used oem from manes. they came in very tight condition. I just wire wheeled them and painted semi flat black. they work great. I thought about buying new also, but glad i didnt. good luck, BROWN 70
06-19-2021, 08:09 PM | #3 |
To me they look like they where (mis-Stamped ) in the press.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
06-19-2021, 08:16 PM | #4 |
Agree with Getter Done, looks like a bad stamp.
My first reman set were loose on the right and looked like they were just repainted. I ordered a new set and the were tight and work great.
1971 GMC C15 Sierra Grande SWB 1972 Chevy C10 Custom Deluxe LWB 2018 GMC Yukon Denali |
06-19-2021, 08:39 PM | #5 | |
06-19-2021, 08:40 PM | #6 |
06-20-2021, 09:19 AM | #7 |
No way I would use them. Send them back. Good used hinges are out there. I have a new, reproduction, set here that doesn't look like that. You can do better. My preference is good used.
Rick |
06-20-2021, 10:26 AM | #8 |
Don't remember, but I'll try to go look. I do know they were reproduction and not refurb'd on my second go round.
06-20-2021, 10:33 AM | #9 |
06-20-2021, 12:48 PM | #10 |
Get your money back. and don't look back.
