Old 06-20-2021, 11:02 PM   #1
mobileortho
mobileortho's Avatar
Shortening a sway bar?
I cannot find a sway bar that works on my mustang ifs. I have two, one came with the kit I purchased a few years back and I recently bought another one that was supposedly for the AD. Eye to eye, they’re measuring 43.75”. The mounting points on the control arms are 39.75”, both are 4” too long.
Unless someone can’t suggest another one, I’m considering trying to shorten one of them. I’ve heard both sides of the argument, some say that rodders have been doing it for years. Others say the heat from welding ruins the heat treatment, turning it into just a steel rod. But I can across these two videos that look promising:
https://youtu.be/ECiJB3CtLyc
https://youtube.com/watch?v=ZCUF-LfxYLo&feature=share
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 06-20-2021, 11:47 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Shortening a sway bar?
i know theyre definitely pricy, but they make a kit that uses a main shaft thats splined on each end similar to a axle , then there are arms that fit over the splines..
you might get lucky with the cut and weld method though
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-21-2021, 09:57 AM   #3
Tempest67
Tempest67's Avatar
can you drill a hole in the lower control arms 2 inches farther out?
Tempest67 is offline   Reply With Quote
Old 06-21-2021, 12:59 PM   #4
jweb
jweb's Avatar
I welded on mounts similar to these to mount my front sway bar
https://www.speedwaymotors.com/Heidt...RoCNP4QAvD_BwE
1951 Truck, LS1/4L60
1964 Suburban, current project
jweb is offline   Reply With Quote
Old 06-21-2021, 02:09 PM   #5
jwhotrod
Paul Hortons welders series has a cut to length swaybar kit that is splined on one end and the other end is cut to length and weld together. that way you can still diassemble the bar. i put one on the front of my 55 frame.
jwhotrod is offline   Reply With Quote
Old 06-21-2021, 04:33 PM   #6
mobileortho
I was just looking at those. I think it’ll be easier to do that than instead of shortening the bar.
Robert C.
1950 3600
Old 06-21-2021, 06:22 PM   #7
jweb
jweb's Avatar
As long as your sway bar has this style of ends/ end links. Those should work.
https://www.speedwaymotors.com/Heidt...BoCMwkQAvD_BwE
Old 06-21-2021, 07:11 PM   #8
mobileortho
The bar is identical. I also see that CCP sells mounts that work with heim joints.
Robert C.
1950 3600
Old 06-22-2021, 09:53 AM   #9
72Mountaineer
72Mountaineer's Avatar
I recently came across the same problem, I tried mounting my sway bar on my 53 3100, but it was too long. I contacted CPP, where I bought the Mustang II kit about 10 years ago, and they said to just shorten it. The bar was threaded for heim joints about 1 1/2 inches deep into the bar so I sawed some off, a little at a time, until it was much better. Is yours the same type?
72Mountaineer is offline   Reply With Quote
Old 06-22-2021, 10:11 AM   #10
mobileortho
I have two bars. The one that originally came with the kit mounts behind the crossmember and it’s threaded. I like that idea! How’s it working out?
Robert C.
1950 3600
Old 06-22-2021, 11:30 AM   #11
_Ogre
_Ogre's Avatar
when i bought my 86 trans am rearend, it came with a sway bar
the eyes on the sway bar were centered on my springs
i just heated the ends and pulled each side in 3", it's worked fine since
if you can't bring in the ends, shorten it, you'll only change the metal in the heat zone
shop air compressor timer
Old 06-23-2021, 05:25 PM   #12
mr48chev
mr48chev's Avatar
That is a pretty good way to have the sway bar break at some time or other though. My wife broke the one on her 79 Chevy Caprice that hadn't ever been heated.
I'd go with the tabs like JWeb showed and just move the mounting point out where you need it.
My ongoing truck projects:
Old 06-24-2021, 08:26 PM   #13
_Ogre
_Ogre's Avatar
why would it cause the sway bar to break?
heating it would remove any temper and make the steel soft, less likely to fracture
heating the ends would have minimal effect on the torsion capabilities
Old 06-24-2021, 08:28 PM   #14
72Mountaineer
It seems to work good, much less "rolling" of the big 'ol front end. Sounds like mine is just like yours.
Old 06-24-2021, 10:38 PM   #15
mick53
Maybe the "soft" part moves and causes metal fatigue? Just guessing.
mick53 is offline   Reply With Quote
Old 06-25-2021, 08:50 PM   #16
_Ogre
_Ogre's Avatar
nope. mr48chev threw out an uneducated guess, as if it were fact
truk sway bar is 1.125" solid steel bar, it's hardly under stress or strain
Old 06-27-2021, 09:58 AM   #17
BBPanel
I used the Welder Series on my 56 Panel w/MII suspension. I bought one of the std length bars splined on both ends - so both ends will come off. I had the arm machined to accept the splined collar and welded it in flush to end of sway bar. It is exactly the right length for my app doing it this way. Not a lot of real estate to work with but it couldn't have come out any better this way. Placement on the a-arm may not be ideal but it will work. I needed the total width to be minimal for tire clearance.
Size:  31.6 KBName:  20190905_161811.jpg
Size:  36.6 KBName:  20191003_104313.jpg
BBPanel is offline   Reply With Quote
Old 06-28-2021, 10:11 AM   #18
mobileortho
As luck would have it, I found this on EBay. It’s the exact measurement I need.
https://www.ebay.com/itm/12381059657...4524#vi-ilComp
Robert C.
1950 3600
