Old 06-21-2021, 03:54 PM   #1
forestb
forestb's Avatar
Door window bump stops
I know that there was a thread about his before. I think I even commented on it but I can't find it.
I am looking for the bumpers that are mounted inside the door that keep the window from rolling down too far.
forestb is offline   Reply With Quote
Old 06-21-2021, 06:00 PM   #2
val1gonzales
Re: Door window bump stops
Are you thinking of these? That go inside the door that the window rests on when opened. This is what I used on my 66.
https://www.classicparts.com/1967-72...ctinfo/18-360/
val1gonzales is offline   Reply With Quote
Old 06-21-2021, 06:18 PM   #3
forestb
forestb's Avatar
yes but for some reason I remember it having two attachment points
Old 06-21-2021, 08:09 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
It's a single stop in the door below the glass, it has a hole in it for a rubber bumper (stop). I showed it in the assembly manual in one of these threads (page 361, item #4). Where to purchase - https://www.steelerubber.com/multi-p...per-33-0459-42
Old 06-21-2021, 10:21 PM   #5
forestb
forestb's Avatar
Were you the one discussing this on a different thread?
That link didn’t work
Old 06-21-2021, 10:40 PM   #6
The Rocknrod
Moderator
Yes I was.
Old 06-21-2021, 10:42 PM   #7
forestb
forestb's Avatar
That looks about right according to the door diagram that was posted.
Old 07-08-2021, 09:01 PM   #8
forestb
forestb's Avatar
I could not find the bracket in the door of my 62. I am trying to figure out how to keep the window from going to far down into the door. When I took my electric window mechanism out to fix a different problem the window now goes even deeper into the door than when I took it apart. It still rolls all the way up which is good. I probably will have to take it apart again.
Old 07-08-2021, 09:17 PM   #9
The Rocknrod
Moderator
Is there a way to place a stop on the power window track?
Old 07-08-2021, 09:28 PM   #10
forestb
forestb's Avatar
It has a Scissor type mechanism. Vary similar to the original type. The only track it runs through are the two on both sides that the original window runs through. I was thinking I might try to add some type of stop on one of those.
Old 05-07-2022, 07:33 PM   #11
The Rocknrod
Moderator
I just looked in the Truck Shop catalog and found the "door window stops" p/n 60-07601.
Page 74 - https://issuu.com/truckandcarshop/docs/ts_60-72_web
