Robert Olson Transport
![]() Join Date: Oct 2002
350 Motor differences
So my own truck is a 98 K 2500 GMC and the lower end of the motor started going and last drain there was a decent amount of metal in the oil so it was time for a motor.. I had a motor i pulled last year from a 97 Tahoe 1500 4wd and as i got my motor out i noticed some differences starting with the truck motor has an extra threaded hole at the top of the bellhousing... is there a difference between these two motors mechanically? ( i also had a HD oil cooler on mine and mine was purchased as a municipality truck)
Re: 350 Motor differences
the 2500 had a beefed up motor compared to the 1500.
The 2500 has 4 bolt mains, forged crank, hypereutectic pistons where the 1500 has 2 bolt mains, cast crank, and cast pistons. Compression and cam specs are essentially the same. You can swap it in but know that it's designed for lighter use.
Mike |
Huh, I never knew that.
#4 | |
The heads are different on my 93. Not sure if they are on those though.
#5 | |
![]() Join Date: Oct 2006
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
#6 | |
Mike |
All about them K’s
![]() Join Date: Jun 2014
There’s a difference in the heads too, the heavy duty motor uses different valve seats too if I remember correctly. I don’t believe it’s cut and dry based on GVW but I do agree 8600+ Is more likely to have the HD motor.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
i can find out. need to replace the motor in my yukon, got one from a crew cab short box C2500. It was the light duty, had the 14 bolt semi float. Looked up casting number and says 2 or 4 bolt. I need to replace the oil pan.
| Bookmarks |
