Old 06-23-2021, 12:30 PM   #1
truckin 79
correct length of 350 oil dipstick
I lost the original dipstick the my 79 and so replaced it with a junyard dipstick but now it seems like it is to long. I just changed oil 5 quarts and it is way over the full line. I thought sbc dipsticks were all the same but I guess not. Can someone give me the correct length? So when I go back to the junkyard I can get the right one.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 06-23-2021, 02:36 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: correct length of 350 oil dipstick
Get the tube with it.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 06-23-2021, 04:03 PM   #3
cadillac_al
I hate to replace the tube. My 76 350 dipstick is 18 1/2" from under the cap to the end.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 06-24-2021, 01:29 AM   #4
Pontiac1976
Pontiac1976's Avatar
If you know for sure the amount oil that your truck took you could just re-mark the dip-stick. Just do not use any van dip-stick in your truck cut it down re-mark it. you have to get the same engine and oil pan as your had( yr, dip stick side left or right, in-let tube style, stock pan or not )
I hope some of this may help
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-24-2021, 09:06 AM   #5
blazer2007
I have one on the wall from a 75 350. Dipstick measures 19 1/2 and tube measures 6 1/2 from top of tube to block
blazer2007 is offline   Reply With Quote
Old 06-24-2021, 11:52 AM   #6
ron350
ron350's Avatar
Looks like these dip sticks are all over the place.
My 75 350 has a 8 inch long tube and a 21 inch long shaft.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is online now   Reply With Quote
Old 06-24-2021, 12:44 PM   #7
ACS
76 350. 21” dipstick with a green cap end.
ACS is offline   Reply With Quote
Old 06-24-2021, 09:12 PM   #8
blazer2007
which sorta equals the same as mine, just longer. Guess depends on options of the car etc. Don, t really know but if it reads right I,m happy
Old 06-26-2021, 06:43 PM   #9
S10Fan
Old Heap Driver
On my hot rod builds I use an aftermarket stick.... Add 4 quarts of oil with a new filter.....Start the car, run it a minute or so, check and mark the stick, add the last quart, run the car, mark the stick, done
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
