Old 06-23-2021, 03:28 PM   #1
8man
48 door window glass
My 48 has the metal trim that goes around the window. I can only find them at LMC and Brothers. Are there other sources? Are they necessary if I have to replace the window channel anyway?
Thanks.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 06-23-2021, 05:21 PM   #2
mr48chev
mr48chev's Avatar
Re: 48 door window glass
You have to buy a special narrow groove channel if you don't run the metal but those windows are pretty fragile without the metal rim. Rough handed Annie slams the door and you have a broken window glass.
Since I am stretching my doors a bunch I am going to have tempered glass made for my truck when I get that far.
My ongoing truck projects:
Old 06-23-2021, 05:38 PM   #3
8man
Thanks Mr48.
8man-aka Robert
Old 06-23-2021, 09:46 PM   #4
mr48chev
mr48chev's Avatar
My buddy had new felt, and new glass in his 48 and the first night he got it out of the upholstery shop a gal slammed the door and broke the glass. His truck obviously didn't have a frame around it. I've never liked the looks of the frame but would be hesitant to run glass without the frames in a stock height window.. Throw in that my 4'10' wife is terrible about slamming car doors on anything she rides in. 52 years of my fussing hasn't fixed that.
Old 06-24-2021, 09:05 AM   #5
youngrodder
youngrodder's Avatar
I personally don't care for the metal trim. I removed it from my last two builds. You just have to run a narrower channel. I have never experienced any cracked windows.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 06-24-2021, 09:20 AM   #6
8man
Marc, what channel did you use? What window? Oh, and did you use the glass channel that goes on the bottom just without the metal trim ring?
8man-aka Robert
Old 06-24-2021, 10:17 AM   #7
youngrodder
I used the channel from the 51-53 (I think) the vent window doors. I can get you a part number. ** THIS CHANNEL IS NARROWWER THAN THE METAL GUIDE IN THE DOOR. NO one makes window channel with the outer dimensions and inner dimensions needed (trust me) I just used a few small screws to secure it. Once all together with the trim and seals it works fine. I had my class custom cut. Just use a window with the trim on for an overall size/shape. Yes you use the normal bottom glass channel. I just cut away the metal surround.
Here is what I used.
http://www.crlaurence.com/apps/conte...ions/2620.html
Cr lawrence 10g96.............window channel
Thank you
Marc
