Old 06-24-2021, 11:49 AM   #1
cericd
cericd's Avatar
Can You Identify These Parts
So, I've accumulated some parts over the years and I have a few that I'd appreciate some help refreshing my memory as to what they are.
Parts 1 & 2 (these were in the same bag. I believe they are for the radio. AM or FM?)
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 06-24-2021, 11:50 AM   #2
cericd
cericd's Avatar
Re: Can You Identify These Parts
Part 3
Chris
Old 06-24-2021, 11:50 AM   #3
cericd
cericd's Avatar
Part(s) 4
Chris
Old 06-24-2021, 11:51 AM   #4
cericd
cericd's Avatar
Part 5
Chris
Old 06-24-2021, 11:52 AM   #5
cericd
cericd's Avatar
Part 6
Chris
Old 06-24-2021, 11:55 AM   #6
pjmoreland
pjmoreland's Avatar
1 = Speaker wires that solder to the tabs on the speaker and plugs into the back of the factory radio
2 = Radio power wire that plugs into the fuse panel on the end that has two connectors, and the other end plugs into the back of your #1 connector
3 = Cigarette lighter power wire
4 = Caged nuts for attaching arm rest to door
5 = Headlight switch
6 = Wiper switch
pjmoreland is offline   Reply With Quote
Old 06-24-2021, 11:56 AM   #7
cericd
cericd's Avatar
Part 7
So I know this is a rear view mirror cover but is it a one year only piece? 1968?
Chris
Old 06-24-2021, 12:22 PM   #8
cericd
cericd's Avatar
6 = Wiper switch
Thanks for the help.
Got a few questions, the only wire that has 2 connectors at on end is part #3. The red wire in the first post only has one connector at each end.
Here's a pic of that wire that shows the whole thing. It does however plug into the back side of the connector on the green wire. Wasn't sure where the other end plugs in.
Also, why does the lighter wire have 2 connectors on one end?
Could those cage nuts be used somewhere else too? For some reason I bought about 10-15 of them.
Chris
Old 06-24-2021, 12:27 PM   #9
pjmoreland
pjmoreland's Avatar
Sorry, my mistake. The cigarette lighter wire is the one with two connectors at the fuse panel end. That's so you can piggyback multiple connectors into the same power socket on the fuse panel.
I can't think of another location where those caged nuts would be used.
Hopefully someone else will chime in on the mirror mount cover. I'm wondering if it is a GMC part.
Old 06-24-2021, 02:00 PM   #10
pjmoreland
pjmoreland's Avatar
Based on these two posts, it looks like that mirror cover might be a 69 only.
http://67-72chevytrucks.com/vboard/s...ar+view+mirror
Old 06-24-2021, 02:41 PM   #11
cericd
cericd's Avatar
69 it is then. Thanks!
Chris
Old 06-24-2021, 03:59 PM   #12
Richard
If I recall correctly, other connector on the cig lighter wire would go to the blower motor relay. Provides direct power for high speed fan.
Richard
Old 06-24-2021, 04:23 PM   #13
LockDoc
The Older Generation
LockDoc's Avatar
The cage nuts are also used at the bottom of the door for the screws that attach the metal door panels.
LockDoc
Leon
