Old 06-24-2021, 07:08 PM   #1
James Pierce
Active Member
CST Tailgate Trim
So wanted to replace woodgrain tape but to my surprise the letters have rivets
on the backside. How do you remove them and replace over new tape.
cascadeheavychevy
67 C10 327 4speed
69 C20 350 4WD 4speed
69 C20 350 4 soeed
69 C20 CST 350 Auto
70 C10 307 4speed
71 GMC Supr 350 Auto
70 C10 350 Auto
67 CST 327 Auto
James Pierce is offline   Reply With Quote
Old 06-25-2021, 01:21 AM   #2
Richard
Re: CST Tailgate Trim
Just one option for removal. Drill them out. I would suggest installing a stop on the drill bit if you want to keep the letters. New rivets can be used for installation or you could source some short sheet metal screws.
Richard
Old 06-25-2021, 05:53 PM   #3
James Pierce
Active Member
Yes I was thinking of drilling them and look into epoxy to install them back. I guess I will drill one and see what it looks like.
cascadeheavychevy
67 C10 327 4speed
69 C20 350 4 soeed
69 C20 CST 350 Auto
70 C10 307 4speed
70 C10 350 Auto
67 CST 327 Auto
Old 06-26-2021, 08:52 PM   #4
atog
Several companies make the metal replacement letters with fasteners. Just a thought and will save a lot of aggravation later.
atog is offline   Reply With Quote
Old 06-26-2021, 10:20 PM   #5
James Pierce
Active Member
Yes I discovered that and ordered a set. I drilled out one letter and the rivet is part of the pot metal casting so as a result not enough left to work with. I also discovered that paint remover takes of the old wood grain tape, bit of labor involved but that is the fun of it all. Thanks for the response.
cascadeheavychevy
67 C10 327 4speed
69 C20 350 4 soeed
69 C20 CST 350 Auto
70 C10 307 4speed
70 C10 350 Auto
67 CST 327 Auto
