Old 06-25-2021, 05:42 PM   #1
72c20customcamper
72c20customcamper's Avatar
Dropped the 68 🤟
3 inch front 4 in the back . Nice and level but I may drop the front an inch or so when I buy the spindles . Now I need shocks any suggestions ? Not looking for top shelf just an ordinary shock that works with the drop
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-25-2021, 05:52 PM   #2
68Gold/white
Re: Dropped the 68 🤟
Woo Hoo!!!
Don't throw those hubcaps away!!!
68Gold/white is offline   Reply With Quote
Old 06-25-2021, 07:30 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Glad it was just springs! When I saw that emoji of a hand with only 3 fingers I was assuming the worst.
~Steven
Simi Valley, CA
Old 06-25-2021, 08:23 PM   #4
tim_mc
tim_mc's Avatar
Looks good! I went with KYB Gas-A-Just absorbers, KG5409 on the front, KG5416 on the rear. I got mine from RockAuto, but Summit will price match if you call them.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 06-26-2021, 08:57 AM   #5
72c20customcamper
Originally Posted by 68Gold/white View Post
Woo Hoo!!!
I keep all the takeoffs on my vehicles. The caps are rough to say the least and the rims are shot lug holes are all warn.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-26-2021, 10:23 AM   #6
Old 06-26-2021, 12:19 PM   #7
tim_mc
tim_mc's Avatar
Hi Mark...attaching a couple of pics of my C20 for reference. The PO of the C10 donor chassis had cut both the front and rear springs and had some jacked up GM (non C10) spindles on the front. I got rid of that mess for CPP 2.5" drop spindles (Summit) and full length Moog front springs (also from Summit). I reused the cut springs in the rear and got lucky with a fairly good stance. Based on the comparison with your pic, I think the KYBs would work, but that might be another reason to buy from Summit as their return policy is great.
Old 06-26-2021, 12:20 PM   #8
Chevys4life
I like that stance for my 1970. Thanks for the spring information.
Chevys4life is offline   Reply With Quote
Old 06-26-2021, 12:36 PM   #9
C101972
For shock information, you can go to CPP website. On there you can find for shock and spring information. Good luck truck looks awesome!
C101972 is offline   Reply With Quote
Old 06-26-2021, 12:46 PM   #10
tim_mc
tim_mc's Avatar
Looking at the pics, I wish I had a little more sidewall to fill the wheel wells like your truck. Currently running Cooper Zeon RS3-G1 235/55R17 tires. 235/60R17 would add about 1" in tire height. If I upgrade the rear end for a posi w/3.42s then I may need tires sooner than expected.
Old 06-26-2021, 01:11 PM   #11
MySons68C20
MySons68C20's Avatar
This is my 68 C20 with 2.5" drop spindles in front and 4" springs + 1" lowering block in the rear. I like the stance of your truck!
Sorry, don't know how to turn pic
MySons68C20 is offline   Reply With Quote
Old 06-26-2021, 01:36 PM   #12
tim_mc
tim_mc's Avatar
Nice! Love the stance, wheels and paint.
Old 06-26-2021, 09:01 PM   #13
72c20customcamper
I’m running 265/70r16 they came off my Tacoma . Lock to lock no rubbing but I haven’t driven it so I can’t tell if it would rub on bumps
Thanks I wasn’t to sure how the paint would come out
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-26-2021, 10:23 PM   #14
PepperTreeGarage
PepperTreeGarage's Avatar
Like seeing the "Big Girls" AKA C20s dropped. Here is the CPP chart for shocks. https://www.classicperform.com/Catal...hock_Specs.pdf
Our '72 C20 Custom Camper.
PepperTreeGarage is offline   Reply With Quote
Old 06-27-2021, 12:52 AM   #15
CG
BlahBlahBlah
OP your truck is screaming for a set of period slotted mag wheels, its really coming along nicely!
Old 06-27-2021, 10:24 AM   #16
72c20customcamper
I’m looking for a set . Not easy to find
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-27-2021, 12:36 PM   #17
72c20customcamper
Shes a 10 . I was going to drop the my 72 but I like the way it rides with the stock suspension mi us a few rear leafs .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-29-2021, 05:55 PM   #18
72c20customcamper
After reading some older threads and this post by GMCPaul
Originally Posted by GMCPaul View Post
I'm surprised none of our customers have responded as we've told all that ask.
ANY, I REPEAT AMY, shock that is made for your stock 1967-72 truck at normal ride height is ALSO the correct shock for those trucks with front & rear drop kits of ANY DROP Height. So if you use 1-5 1/2" drop in the front you still use the same shock. If you use 1-6" drop in the rear you still use the same shock. ECE, No limit, Classic, Brothers, everyone is selling shocks that are made to stock travel specifications. Now your asking why this is true. The reason is with any of the drops I listed above the stock shocks minimum & maximum travel distances are not exceeded. Since the shocks travel limits are still within spec, the stock shock length is still used.
NOW in the rear once you hit about a 5" rear drop the shock has become to horizontal to absorb vertical travel effectively. So you then install rear shock relocators in the rear to make the shocks more vertical again so that they can then absorb the vertical travel of the truck. ( It's also my understanding though I have not tried it yet, that if you move the rear lower shock bracket from left side to the right, and the right side to the left this will also correct the shock angle back to a more vertical position eliminating the need for rear shock relocators. ) But again I've not checked this myself on just swapping the lower mounts from 1 side to the other. I'm just reporting what I've heard from several low budget builders.
So everyone should determine the type of ride that you want based on you and your driving habits then look up the shocks and look for comfort, sport, off road etc.... based on your driving style & preference's and then purchase the stock shock for your truck in that type of shock. KYB GR-2 soft comfortable ride, KYB gas a just shocks give a firmer ride , etc.....
Then buy from who you choose. If your already buying parts from 1 location and the shocks they have only cost a little more than the cheapest place you've found get the shocks from where your buying your other parts unless your getting free shipping.
Hope everyone is Healthy, Happy, & Prosperous in 2016 and beyond.
Paul @ GMCPauls
I have decided to keep the shocks that were in it fairly new Monroe Gas shocks .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-29-2021, 06:00 PM   #19
72c20customcamper
Was looking into changing out the rear bumper to another one I have . But the damn this is welded to the frame with what looks to be 1/2 inch plate steel . Also the tow hitch is welded to the bumper and the frame again with heavy steel plate . So I'm just going to modify it in place cut off the wings around the lower bedside and finish it .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
