06-25-2021, 07:43 PM | #1 |
flex plate cover
I have 69 C10 I have owned for 31 years . It has the original TH350 in it . Somewhere along the way I must have misplaced the original flex plate cover .
I have a flex plate cover from some other GM/chev truck and the 4 bolt holes don't all line up correctly to the trans and when I try to use it the flex plate (or TC) rubs it when engine is running . How do I go about finding the correct flexplate cover for my truck ? Thanks for any help . |
06-25-2021, 10:36 PM | #2 |
Who Changed This?
Re: flex plate cover
Just grind the holes so that the cover is further away from the flex plate and converter.#cheepniss If that isn't your preferred solution, I'm sure someone else will come along with something better, but costs more money.
06-26-2021, 01:25 PM | #3 |
I got one off the parts board here on the site. Just keep your eyes open for one, they show up fairly regularly. I think I paid about $35 or so with shipping. Just make sure it’s for a small block and it should work. Not sure if auto or manual trans makes a difference though…
You can also pay to become a member, and then you can post a Want To Buy (WTB) on the parts board. Good hunting.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
07-01-2021, 09:24 AM | #4 | |
07-01-2021, 03:50 PM | #5 |
I have added or replaced several of those dust covers over the years and have yet to see one that bolted right up...they have all needed a little hole reaming or massaging to fit.
07-01-2021, 04:16 PM | #6 | |
Automatic FlexPlate Covers are one-piece. No interchange.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 07-03-2021 at 09:40 PM. |
07-01-2021, 06:32 PM | #7 |
Two different covers for the 350 automatic. Steel and plastic. I would try for a steel version, plastic breaks down eventually.
71 C-20 07 Magnum RT AWD |
07-03-2021, 08:18 PM | #8 | |
Haven't been able to find a replacement anywhere...
1972 Cheyenne Super LWB, 350V8, AC, PS, PB, all original 46k survivor |
07-04-2021, 12:10 PM | #9 | ||
