06-25-2021, 08:27 PM | #1 |
Under-bed gas tank without removing the bed or rails?
I was wondering if it is possible to install an aftermarket tank, or one from another vehicle under the bed, and not have to remove any rails. There's gotta be someone that has done this, I hope.
My plan would be to do the side fill, not the in-bed fill.
1963 C20, small window, long bed 292, 4-speed |
06-26-2021, 02:03 AM | #2 |
Re: Under-bed gas tank without removing the bed or rails?
The Camoro gas tank FAQ is what you seek
06-26-2021, 02:36 AM | #3 |
06-26-2021, 09:01 AM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
A Boyd’s attaches under the frame rails
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-26-2021, 12:15 PM | #5 |
I checked out the Camaro tank; doesn’t look too bad. However, my bumper doesn’t have the license plate in the middle, I would have to modify it or get a different bumper.
I think I’ll just leave it for now, just wish I could get my gas gauge to work. I tried the resistor trick, but it still doesn’t read right.
06-26-2021, 10:51 PM | #6 |
This is the tank I had made to mount between the last two crossmembers in the frame, side fill
06-26-2021, 10:54 PM | #7 |
Where did you get that tank?
06-26-2021, 11:32 PM | #8 |
Maybe you just need a new sender. https://www.tanksinc.com/index.cfm/p...rod/prd831.htm
06-27-2021, 07:57 AM | #9 |
06-27-2021, 08:02 AM | #10 |
Moderator
That was smart. I found the same negative response from machine shops. I'll remember this.
06-27-2021, 09:19 AM | #11 |
I did a newer suburban tank in my 62 burb with bands to hold it up works good dident have to remove anything to install. Might give you an idea.
06-28-2021, 12:12 AM | #12 |
Just looked it was a 73-81 Blazer tank 25 gallon I moved the filler to the side because I wanted the straps to go from side to side because of the cross suport.
06-28-2021, 08:41 AM | #13 |
I put one in from a Jeep CJ hanging on some bed frame angle iron to the truck frame rails and got a fill setup from a Dodge P/U mounted just inside the box. It fills nicely. So far my problem is that I still need to get a sending unit to match the truck gauge. Currently I top it up about every 100 miles.
06-28-2021, 09:09 AM | #14 |
A mid 60s mustang tank slides between the rails nicely - to make it removable you would need to make the rear crossmember bolt in (which is what I had done) and I think this would allow you to fit and service the tank without removing the box. You may need to lift the rear of the box though to clear the main box cross member. I can send pics later this week if you are interested.
06-28-2021, 09:59 AM | #15 | |
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
06-28-2021, 10:01 AM | #16 | |
yes - its quite small - 16 gals.
i fitted a 7 inch tube style sender that is 0-30 ohm so connects with the stock gauge nicely. Quote:
06-28-2021, 10:48 AM | #17 |
You know that using the original gauge and a new sending unit it only needs a resistor to make it work. couple threads on here as a how to.
http://67-72chevytrucks.com/vboard/s...d.php?t=210638 |
06-28-2021, 11:41 AM | #18 | |
06-28-2021, 11:42 AM | #19 | |
06-29-2021, 02:15 PM | #20 |
Here's my early Mustang tank It's only about 16 gal., though. but it fits nicely between the frame rails. When I ordered my gauges I just got one to match the Mustang sender.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
06-29-2021, 03:17 PM | #21 |
exactly the same as my setup - apart from I mounted to the lower frame - the mustang tanks fit up nicely and bolt to the rails along the perimeter.
06-29-2021, 07:53 PM | #22 | |
07-05-2021, 06:09 AM | #23 |
I used the Jeep tank, I do have my bed off but as there is no trimming needed of the rails this 'should' be an easy fit with the bed on.
It is a side fill as well which should make things easier - only downside is capacity but that is not really a problem for me. Have pictures on my thread or can send them to you if you let me know your details. P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
07-05-2021, 09:59 AM | #24 |
I think I may lower the Jeep tank and cut a hole for a sender so that I can get it back to the 0-30 ohm gauge.
