Daily a 71-72 k10/20
Anyone out here daily a 71-72 k10/20 I will occasionally drive on the interstate about 300 mile round trip, speed limit is 75mph so I’m assuming I’ll need overdrive. How’s reliability with a stock truck? How is starting in the winter? It gets to be pretty cold up here -20 isn’t uncommon.
1959 GMC 100 3 on the tree 270. 1968 GMC k2500 Stepside 1972 Chevy Monte Carlo Custom. |
Re: Daily a 71-72 k10/20
My son uses his daily year round. Its a 70 GMC 4x4. Motor is a 5.7 with tbi from a late 80s truck with 700R4 trans. No problems but he does plug it in during cold spells.
I had a 72 4x4 when he was little that I used all year. It was original with a quadra jet carb. As long as maintanance is kept up I dont see a reason to not use them. Jeff |
#3 | |
I daily drive my 72 Blazer. It starts every time and gets me wherever I'm going.
As far as overdrive, what engine/transmission/rear end/tire size are you running?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
![]() Join Date: Feb 2014
There’s a thread about 2 posts away with exact same question
2002 Duramax I love 1971 k10 4x4 longbed 350/350/205 all original |
Well, im trying to figure out if I would need one and im thinking I will, speed limit is 75 and traffic goes 80. Im basically debating selling my 02 2500HD and buying a 71-71 4wd for a daily and trying to see if it is feasible for what I do. I really only would need to drive highway 1 time a year for hunting 120 miles away.
I have a 350/350 with 3.73 gears and 33" tires. It runs fine at 80.
At 3000 RPM? can’t imagine that’s decent for the motor or gas milage.
#9 | |
![]() Join Date: Oct 2009
3000 on the highway wasn't that uncommon back in the land before overdrives - but now that we're used to cruising at 2100 RPM, 3000 feels like it's screamin. Doesn't really hurt the engine, per se, but it does affect fuel economy of course. |
-50 my truck in the back yard was the only truck in the yard to start
68 gmc 4x4 350 4x4 . Good cold crank battery good tune up good antifreeze I always mix 60 40 synthetic oil good to go |
#11 | |
A small block Chevy - any engine, for that matter - should be able to run 3000 RPM all day with no negative effects. Fuel mileage isn't going to be great no matter what RPM you're running, as pushing a brick through the air at 80 MPH takes a lot of energy. If you're considering an overdrive to improve fuel mileage, take a minute to figure out how long it's going to take you to recoup your investment.
#13 |
![]() Join Date: Jan 2018
Gear Vendors in my '72 Jimmy was definitely one of the best modifications I did to the rig!
350 transmission, 33" tires and 410 gears. Cruises real nice at 75-80mph. Went across Nevada last year and many times was cruising 85-90. But.....don't even think that you're going to get decent fuel mileage. I don't really know how, but a few times I was just a hair over 12 mpg. Most of the time though I'm between 10-11 mpg. Pat |
