Old 12-23-2003, 12:17 PM   #1
griesel72
griesel72's Avatar
Quick Help with pwr steering
will the new style pwr steering pump work on a 71 4X4, i'm all ready to slap in the motor, but just need to know.
Thanks for any help
David
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 12-23-2003, 12:27 PM   #2
Randy70C-10
Randy70C-10's Avatar
As far as I know a pump is a pump. Does it fit?
Randy70C-10 is offline   Reply With Quote
Old 12-23-2003, 12:36 PM   #3
griesel72
griesel72's Avatar
i haven't tried yet, it is the one that mounts to the newer style manafolds, so i guess i'll try it and see.
David
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 12-23-2003, 12:41 PM   #4
Huck
Huck's Avatar
The pump may bolt up to the frame but check the hose fittings=--they changed some time in the late 70's--early 80's
Huck is offline   Reply With Quote
Old 12-23-2003, 05:14 PM   #5
tom hand
CCRider
tom hand's Avatar
You can use a newer pump....on the original brackets or the newer brakets depending on what setup you have. At some point they changed to o-ring fittings but that is no big deal...the part that is different screws into the back of the pump so you can change it out with the older flare fitting style.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
