Old 06-28-2021, 02:40 PM   #1
Chris Baker
Chris Baker's Avatar
1962 235 hydraulic clutch flex hose
Hi I recently replaced the brake lines on my '62 and the kit came with two stainless sections of clutch line but no flex hose between them. Anyone find one or a solution? Thanks, Chris
Chris Baker is offline   Reply With Quote
Old 06-28-2021, 03:50 PM   #2
bhap
bhap's Avatar
Re: 1962 235 hydraulic clutch flex hose
I used a piece of stainless braided hose with fittings on either end to connect to the hard lines. I only needed about 8". If you have a hydraulic hose shop around, they should be able to make one up for you.
bhap is offline   Reply With Quote
Old 06-28-2021, 04:51 PM   #3
gpk1961
I think your solution is the only way to go. I can't find anyone that makes a clutch line like the original (I have a 61 C-10). Any pictures would be helpful. Thanks - GPK1961
gpk1961 is offline   Reply With Quote
Old 06-28-2021, 10:50 PM   #4
slepysal
slepysal's Avatar
My old one and one I had made at a local shop "Royal Brass"
Name:  slave cyl hose.jpg
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 06-29-2021, 10:24 AM   #5
gpk1961
Thanks Sal. Very helpful. GPK1961 Frisco TX
Old 06-29-2021, 01:17 PM   #6
62K20
62K20's Avatar
I had one made at a local hydraulic hose shop for $45.00. Here a picture of the old one with some measurement.
62K20 is offline   Reply With Quote
Old 06-29-2021, 01:31 PM   #7
gpk1961
Thanks, again very helpful. GPK1961
Old 07-01-2021, 12:54 PM   #8
Chris Baker
Thanks for the solutions guys. I think the hydraulic hose from a shop sounds like it would be the most original looking. CB
Old 07-04-2021, 10:26 PM   #9
j.kirn
I bought mine at inline tube
j.kirn is offline   Reply With Quote
