Old 06-28-2021, 11:47 PM   #1
Indyspecracer
Window regulator installation ??
So I’m getting ready to install the door internals, have read all of the threads and watched videos and have an unanswered question.
The top two rollers on the regulator go in the window sash. Where does the lone bottom roller go? I don’t see anything on the door that would suggest that there is a lower channel that it rides in. Thanks in advance.
Indyspecracer is offline   Reply With Quote
Old 06-29-2021, 01:47 AM   #2
pjmoreland
pjmoreland's Avatar
Re: Window regulator installation ??
There is a small track attached to the back of the inner wall of the door where that lone roller rides. You can see it if you roll your window down all the way and shine a flashlight down into the window opening.
pjmoreland is offline   Reply With Quote
Old 06-29-2021, 11:20 AM   #3
Custom 68
Custom 68's Avatar
This track is above the big opening on the inside of the door. Depending on where the "crank" is positioned that lone roller could be above or below the other two if that makes sense.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 06-29-2021, 11:48 AM   #4
MySons68C20
MySons68C20's Avatar
I found Randy500's post to be very helpful.
https://67-72chevytrucks.com/vboard/...d.php?t=732400
MySons68C20 is offline   Reply With Quote
Old 06-29-2021, 09:54 PM   #5
Indyspecracer
So I have an original door and intervals for both left and right doors. I done have the track that the lower roller rides in. Does anyone know if they are reproduced and what they are called? Thanks!
Old 06-29-2021, 09:59 PM   #6
Indyspecracer
Never mind! I just found it. Thanks again
