What is this stuff called?
It is kind of tacky but is used as insulation for the copper pipes on this evaporator. I need to find some more of this stuff to seal it back up again. I am just about ready to flush and put new hoses on this unit. Also anyone know what the probe is used for that goes into the fins? You can see in first picture the probe and then the crusty round circle that it went into. The wires are connected to a little black box,so not sure if it is just another safety switch not sure.
79 Chevy 2wd BIG10 350 TH400 Last edited by truckin 79; 06-30-2021 at 01:12 PM. |
#2 | |
Re: What is this stuff called?
I think it's a type of butyl rubber.
![]() Join Date: May 2015
3m strip caulk
![]() Join Date: Mar 2003
At the parts store it is called the AC sticky tar insulating stuff---works for me when I go there
Haha...KW, youd probably have better luck asking for it that way than if you had a part number
If you don't have any luck at the autoparts store, might try an home AC shop. I have seen similar in some inside cold coils on residential split units.
Probe might be the anti-freeze probe. More likely if the black box is wired in series with the compressor wiring. On my 75, the probe is a metal tube. |
![]() Join Date: Oct 2014
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
What Hump?
Is this what your looking for?
Dayco 80170 - Dayco Autoflex Defroster Duct Hoses ( 13 ) Part Number: DAC-80170 Dayco 80170 - Dayco Autoflex Defroster Duct Hoses Made in the USA https://static.summitracing.com/glob...80170.jpg?rep= $28.99 Dayco Autoflex Defroster Duct Hoses Duct Hose, Black, 2.50 in. Diameter, 6 ft. Length, Each See More Specifications | Check the Fit In Stock (more than 10 available)
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
I just bought this. Has flat sheets of it in the kit.
https://www.classicparts.com/1967-80...tinfo/HA-8708/ |
#11 | |
Eyegore I was not looking for the ducting quite yet but thanks for the source. Dead Parrot looks like you are correct it is a sensing bulb that will cycle the compressor if the evap freezes up.
79 Chevy 2wd BIG10 350 TH400 |
i buy it by the foot from my aftermarket car ac store. They sell custom ac hoses and complete aftermarket ac systems for hot rods.
| Bookmarks |
