Old 07-02-2021, 12:51 PM   #1
Hook'em
Hook'em's Avatar
Disc brake replacement pads
I put on a front disc brake conversion kit in 2005 from Early Classic Enterprises - which is now closed. I'd like to purchase replacement pads before pulling everything off, but unsure which pads it uses. Anyone know what brake pads are needed for a replacement?
Hook'em
Hook'em is offline   Reply With Quote
Old 07-02-2021, 12:59 PM   #2
tdangle
tdangle's Avatar
Re: Disc brake replacement pads
If the kit is anything like what I just got from POL, it probably uses the stock disc pads for 71-72 years. No one is going to make a custom caliber and set of pads when they can just use factory ones. I would take the pads off and take them with you to the auto parts store.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 07-02-2021, 01:07 PM   #3
gmc684x4
They will be a set that will fit 71 to 79 sometime after 79 they are renamed hd brakes when gm came out with a light duty brake
gmc684x4 is offline   Reply With Quote
