Old 07-02-2021, 01:58 PM   #1
chris989
sanden 508 upgrade
Hello all,
Finally giving up and the R4 turd and installing a 508 sanden. The sandens are listed with 7 or 8 groove pulleys. Anyone have insight on which will cause less problems?
Am I over thinking it?
Thanks,
Chris
chris989 is offline   Reply With Quote
Old 07-02-2021, 06:28 PM   #2
Sabaka454
Sabaka454's Avatar
Re: sanden 508 upgrade
How many grooves is your drive belt?
Sabaka454 is offline   Reply With Quote
Old 07-02-2021, 09:36 PM   #3
v30crewcab
v30crewcab's Avatar
doesn't matter. get the 8 groove, and only use 6.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 07-03-2021, 11:43 AM   #4
chris989
I currently have 6,,, was going to order vintage air a 7 groove. Called and they confirmed it was a new Sanden and not a knock off.
Old 07-09-2021, 11:07 AM   #5
chris989
Hello again,
WHo has done thisupgrade and how many tweeks did it require.
Here is my short list for the "bolt on" conversion.
From Dirty Dingo I orderd;
a new 508 made in USA.
billet manifold end so i could use the OE lines.
bracket kit
1- the lines exiting the rear of the comprressor interfer with the map sensor bracket stuff.
2- line set interferes with the dipstick.
3-liquid line is short.
4 if i leave the sanden head and fittings on they interfere with the air cleaner.
Ideally i would like a few modifications as possible so off the shelf items work in the future. I hate to start hacking at parts only to find another short coming.
Is there a bracket that lifts the sanden up/out a little more to clear the valve cover and map?
thanks,
Chris
Old 07-09-2021, 09:05 PM   #6
Sabaka454
Sabaka454's Avatar
I bought a set of brackets on eBay and they worked out great.
Old 07-10-2021, 12:18 PM   #7
chris989
The brackets that i bought work well. The billet manifold to use OE hoses did not. Still have to make or extend the high/liquid line.
I went to my ac shop yesterday and they are a month out from taking any new work.
Old 07-10-2021, 09:44 PM   #8
Sabaka454
Sabaka454's Avatar
Buy the beadlock fitting tool (71500) and a beadlock hose kit on eBay, then you can make your own.
Old 07-11-2021, 10:08 AM   #9
chris989
That is what i will do, I can use it on future builds too.
