07-05-2021, 03:04 PM | #1 |
How did this happen to window gasket?
I installed my rear window and it looked great.... for several weeks. Then this happened. It appears to have puckered and pulled away from the glass on top. Any ideas? I have bought a new gasket and lock strip but would like to understand what happened so it doesn't happen again. Couldn't get the image to be correct but the pucker is on the bottom flat.
07-05-2021, 07:29 PM | #2 |
Who Changed This?
Re: How did this happen?
Won't know why until it's out, but it is probably split. Is the stainless trim new, as well as the gasket?
07-05-2021, 08:00 PM | #3 |
Post Whore
I was gonna say its probably split between the inner and outer face..but Steve beat me to it
07-05-2021, 11:07 PM | #4 |
07-06-2021, 11:46 AM | #5 |
Not sure what causes the issue.
I rotated the image to get a better view for for those that might be able to answer.
07-06-2021, 01:33 PM | #6 | |
07-06-2021, 02:49 PM | #7 |
Post Whore
thats the trim piece that goes over the meeting ends of the lock strip..it goes in the seal over the lock strip
07-06-2021, 03:12 PM | #8 |
07-06-2021, 04:25 PM | #9 |
Post Whore
yep...2:26 and 11:45 shows how it comes out and goes in
https://www.youtube.com/watch?v=ufZW2CnhOS0
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 07-06-2021 at 04:36 PM. |
07-07-2021, 11:01 AM | #10 |
It's Better With Nitro
As a couple of the others mentioned earlier, it might be that the seal cut/tore while putting in the lock strip (for the rear window, I hope the lock strip wasn't steel). My friend's rear seal did that a few years back and when we removed the glass and seal, it was indeed split inside at that area and started to pull away.
When installing the lock strip, be sure to spray generous amounts of the lubricant solution of your preference (I used an old spray bottle with a water dishsoap solution) as you install the lock strip, and don't be too aggressive with the lock strip tool as you insert the strip. I have not seen a rear window lock strip with that center trim piece.
07-07-2021, 12:54 PM | #11 | |
07-07-2021, 03:31 PM | #12 |
Moderator
Neither have I.
07-07-2021, 03:58 PM | #13 |
Post Whore
My 81 has them on the back, but theres one on each side lower corner..its L shaped
The front has a single like you showed, bottom center of windshield..
07-16-2021, 02:28 PM | #14 |
Pulled out the lock strip and can see what happened. There is a tare in the weatherstrip. Factory flaw or possibly did it with the lock strip tool. Ready to reinstall with new weatherstrip.
