Old 12-23-2003, 06:45 PM   #1
skokie
skokie's Avatar
400 turbo kickdown solenoid
How hard is it to change out a defective kickdown solenoid in a 400 turbo tranny? This is the piece that is on the tranny itself. Just for clarification.
thanks
skokie is offline   Reply With Quote
Old 12-23-2003, 08:46 PM   #2
Chevy67Tk
Chevy67Tk's Avatar
Not hard at all.
1. Drain pan if you have a plug, if not get a big drip pan to catch all the oil when you drop the pan
2. Drop the pan
3. Remove the filter(you might as well change this while you have it apart this far)
4. Un-hook wire for solenoid from connector in transmission.
5. Remove 2 bolts holding solenoid.
6. Install new solenoid and hook up wire Note: some take a metal shim gasket some have a built in o-ring deal.
7. Install new filter
8. Re-install pan
9. Fill with oil
10. Run and re-check fluid level and for leaks
Chevy67Tk is offline   Reply With Quote
