Old 07-09-2021, 07:32 PM   #1
HeloCrewChief
HeloCrewChief's Avatar
New gas tank straps
I purchased a new fuel tank kit from motor city k5 and the straps fit terribly. Any other options out there? I’m having no luck finding used ones.
1970 C10 to K20 conversion
1974 GMC Jimmy
1968 50th Anniversary Short Bed
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
HeloCrewChief is offline   Reply With Quote
Old 07-09-2021, 07:43 PM   #2
Tuff Gong
Tuff Gong's Avatar
Re: New gas tank straps
Wtf
Tuff Gong is offline   Reply With Quote
Old 07-09-2021, 07:54 PM   #3
Thealien
Thealien's Avatar
The L part of the bolt goes through the frame not through the strap.
You will then flip the strap around 90° so that when it comes up from the tank the L faces away from the tank and the bolt will go through that flange. They work fine.
Old 07-09-2021, 11:20 PM   #4
HeloCrewChief
Thank you for the reply but, not quite sure I follow. If I flip the strap upside down essentially, the bolt will not go through as the hole opening is in the side. Do you have to bend the bracket itself at a 90?
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
Old 07-10-2021, 12:53 AM   #5
Tuff Gong
Tuff Gong's Avatar
I think the strap will bend around the tank and turn up enough for the bolt attachment.
Old 07-10-2021, 08:50 AM   #6
litebulblsc
litebulblsc's Avatar
The hook of the bolt goes in the frame with the nut down so you can tighten it. The straps need flipped so the bend points inward toward the tank.
litebulblsc is offline   Reply With Quote
Old 07-10-2021, 10:21 AM   #7
HeloCrewChief
Thank you for the picture. I’ll throw them in the vice and get them bent over. Just not sure why they didn’t come with the correct bend in them.
Old 07-10-2021, 01:41 PM   #8
Tuff Gong
Tuff Gong's Avatar
You just need to flip them over. Vice is not needed
Old 07-10-2021, 03:05 PM   #9
roboticjunky
Look at Post #7 in this other thread. http://67-72chevytrucks.com/vboard/s...d.php?t=190563
roboticjunky is offline   Reply With Quote
Old 07-10-2021, 03:43 PM   #10
Thealien
Thealien's Avatar
Sorry my drawing skills are not very good but this should help you get it done. No need to bend the straps just flip them over.
Old 07-10-2021, 07:14 PM   #11
litebulblsc
Couple pictures of how I have mine on the left and right side.
Apparently Suburbans are different (link above)
Old 07-11-2021, 10:24 AM   #12
HeloCrewChief
Right on. Will give it a shot this week. I was thinking adding a bend as they were bowing and making a gap under the center of the tank. I also plan on running some sound deadening type material under the strap as an anti squeak strip.
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
Old 07-12-2021, 12:03 PM   #13
SeventyOne
As you tighten them up that gap under the tank should go away. And yes 100% run some isolating rubber under the tank straps, and between the tank and the frame like the factory did.
As far as i know no one reproduces the parts but I bought some sheet rubber and used my old ones as a template.
SeventyOne is offline   Reply With Quote
