Old 07-11-2021, 07:43 AM   #1
Larry S
Larry S's Avatar
Maxi fuse mount / wire routing
I am using American Autowire classic update kit. Id like to see where some of you are mounting maxi fuse and how you are routing wires to starter and alternator. Id like to hide it as best as possible. Thanks.
Larry S is offline   Reply With Quote
Old 07-11-2021, 08:55 PM   #2
LS short box
Re: Maxi fuse mount / wire routing
A bit hard to see but here's a pic of the maxi fuse mounting under the heater box. Short run to the starter stud. Then all other wires routed behind the engine block.
LS short box is offline   Reply With Quote
