Old 07-11-2021, 04:24 PM   #1
Jimmie
Jimmie's Avatar
Smile Re-Ring
I would like to re-ring my 71 350 engine. Has any one here pulled the heads and raised the block up some to remove the oil pan to remove the pistons ?
Jimmie is offline   Reply With Quote
Old 07-12-2021, 10:25 AM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Re-Ring
In my opinion, it would be a lot easier to pull the engine. It'll be a lot easier to get at everything and clean things properly.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-17-2021, 07:55 PM   #3
hemi43
hemi43's Avatar
Re: Re-Ring
You can't just throw a set of rings in without deglazing the bore, and you can't do this with the crank installed because the counter weights will be in the way.
hemi43 is offline   Reply With Quote
