Old 07-14-2021, 04:35 PM   #1
conoco
conoco's Avatar
Front Grill and Clip install
I recently pulled the entire front clip while I replaced my rockers and I ended up sound proofing everything under the wheel wells and also the inside. I put everything back together ( Doors, both fenders, front bumper, grill and lights) everything installed correctly, well the lines match up at least. But the hood is a little hard to shut. The only thing I can thing of is that there are 2 bolt holes on the top of the grill. I don't know if the grill is suppose to slide under the holes or rest on top.
If they rest on top like they currently are, there is like a 1/4 inch gap and it wouldn't make sense that any bolts would go in the holes because nothing is sitting flush. I don't think I can slide them under either. The center support for the radiator wont allow it on one side.
To summarize a very confusing explanation I just gave can someone tell me what these holes are for and how the grill mounts to them. Like I said. The hood shuts all the way and the lines all match, but it doesn't close anywhere close to how it did before I took everything off. I really have to shut it now for it to close all the way.
conoco is offline   Reply With Quote
Old 07-14-2021, 04:53 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Front Grill and Clip install
The latch goes on top of the grill . You can see the witness mark .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 07-15-2021, 09:58 AM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by grumpy old man View Post
the latch goes on top of the grill . You can see the witness mark .
x2
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
