Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-16-2021, 11:23 AM   #1
mbuchli
1957 10100 Task Master - Info needed
Hey everyone,
I have a 1957 Task Master with a 322 and the double drive shaft tandem axles, I would like to get a little more info and was hoping that you could help?
https://photos.app.goo.gl/vty7oWw5tS7amYSy7
Mike
mbuchli is offline   Reply With Quote
Old 07-16-2021, 12:38 PM   #2
MJN
MJN's Avatar
Re: 1957 10100 Task Master - Info needed
Not sure what information you're after but this info packet has a lot of great data in it to get familiar with the 1957 trucks.
https://www.gmheritagecenter.com/doc...olet-Truck.pdf
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 07-16-2021, 01:30 PM   #3
greystoke
My mind went into imagine mode when I saw your truck. Crazy potential!!!
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline   Reply With Quote
Old 07-16-2021, 04:18 PM   #4
mbuchli
Thank you, I will take a look. I was also looking at seeing if there are other trucks out there I could use for reference. I have never seen one like this and wanted to see how many others have been around one or have one.
Mike
Old 07-18-2021, 11:40 PM   #5
Bobb
Hy mbuchli, there is another similar tandem owned by an A.T.H.S. member, it has a 322 Buick engine as well and it also has the Powermatic automatic transmission. A rare truck to be sure, I have a 1957 Chevrolet 8700 tandem, but it only has a 283 in it. Good luck with yours.
Bobb is offline   Reply With Quote
Old 07-19-2021, 09:06 AM   #6
mbuchli
Thank you Bob for the info! Mine is a manual trans with a brownie behind it. I would love to see pics of your 8700!
Old 07-19-2021, 09:45 AM   #7
Bobb
Hy mbuchli, are you sure your tandem has a brownie, or are you thinking of the power divider? One input from the transmission, two outputs to the two differentials.
Old 07-19-2021, 10:03 AM   #8
mbuchli
it could be the power divider vs. brownie. I didn't inspect it closely when we pulled it from where it has been resting for almost 40 years.
