07 avalanche p0302 code driving me nuts...
hey guys, i bought a 07 avalanche, 5.3L 2wd. it has a p0302 code and I cant seem to get it to go away.
what I've done so far... Plugs Wires Coils Injectors Smoke test (found a broken pcv pipe on the drivers rear of engine...repaired) it does have a little miss at idle, my next recourse will be compression test on the cylinders and look at the cats. I pulled live data today with my scanner but don't see anything here is a readout sample, tell me if you see anything in the data. Thanks in advance! CRUISING AT 60MPH Numbers of DTCs 0 Fuel system 1 statusCL Fuel System 2 statusCL Calculated Load Value(%)60.0 Engine Coolant Temperature(¡£F)197 Short Term Fuel Trim -Bank 1(%)-7.0 Long Term Fuel Trim - Bank 1(%)0.0 Short Term Fuel Trim -Bank 2(%)0.0 Long Term Fuel Trim - Bank 2(%)-0.8 Intake Manifold Absolute Pressure(psi)10.0 Engine RPM(rpm) 1786 Vehicle Speed Sensor(mph)61 Ignition Timing Advanece for #1 Cylinder(¡£)27.0 Intake Air Temperature(¡£F)93 Air Flow Rate from Mass Air Flow Sensor(lb/s)0.09 Absolute Throttle Position(%)37.3 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.200 Short Term Fuel Trim Bank 1-Sensor 1(%)1.6 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.600 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.480 Short Term Fuel Trim Bank 2-Sensor 1(%)0.0 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.560 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBD&OBDII Time Since Engine Start(sec)3951 Distance Travelled While MIL is Activated(miles)0 Commanded Evaporative Purge(%)93.3 Fuel Level Input(%)14.5 Number of warm-ups since diagnostic trouble codes cleared0 Distance since diagnostic trouble codes cleared(miles)1 Evap System Vapor Pressure(inH2o)-4.336 Barometric Pressure(psi)14.8 Catalyst Temperature Bank 1,Sensor 1(¡£F)1385 Catalyst Temperature Bank 2,Sensor 1(¡£F)1673 Control module voltage(V)13.497 Absolute Load Value(%)41.6 Commanded Equivalence Ratio0.999 Relative Throttle Position(%)23.5 Ambient air temperature(¡£F)89 Absolute Throttle Position B(%)36.5 Accelerator Pedal Position D(%)28.6 Accelerator Pedal Position E(%)14.1 Commanded Throttle Actuator Control(%)33.7 Alcohol Fuel Percentage(%)3.1 IDLING IN THE DRIVEWAY GETS CODE Live Data Numbers of DTCs 1 Fuel system 1 statusOL-Fault Fuel System 2 statusOL-Fault Calculated Load Value(%)18.0 Engine Coolant Temperature(¡£F)195 Short Term Fuel Trim -Bank 1(%)0.0 Long Term Fuel Trim - Bank 1(%)0.0 Short Term Fuel Trim -Bank 2(%)0.0 Long Term Fuel Trim - Bank 2(%)-0.8 Intake Manifold Absolute Pressure(psi)5.1 Engine RPM(rpm) 599 Vehicle Speed Sensor(mph)0 Ignition Timing Advanece for #1 Cylinder(¡£)15.0 Intake Air Temperature(¡£F)116 Air Flow Rate from Mass Air Flow Sensor(lb/s)0.01 Absolute Throttle Position(%)21.6 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.810 Short Term Fuel Trim Bank 1-Sensor 1(%)0.0 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.675 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.715 Short Term Fuel Trim Bank 2-Sensor 1(%)0.0 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.925 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBD&OBDII Time Since Engine Start(sec)100 Distance Travelled While MIL is Activated(miles)0 Commanded Evaporative Purge(%)0.0 Fuel Level Input(%)13.7 Number of warm-ups since diagnostic trouble codes cleared0 Distance since diagnostic trouble codes cleared(miles)5 Evap System Vapor Pressure(inH2o)0.018 Barometric Pressure(psi)14.6 Catalyst Temperature Bank 1,Sensor 1(¡£F)897 Catalyst Temperature Bank 2,Sensor 1(¡£F)890 Control module voltage(V)13.571 Absolute Load Value(%)17.6 Commanded Equivalence Ratio0.909 Relative Throttle Position(%)8.6 Ambient air temperature(¡£F)104 Absolute Throttle Position B(%)21.6 Accelerator Pedal Position D(%)18.8 Accelerator Pedal Position E(%)9.4 Commanded Throttle Actuator Control(%)12.2 Alcohol Fuel Percentage(%)3.1
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
Re: 07 avalanche p0302 code driving me nuts...
With the data provided, was the idle data after you drove it and came back to the house? You have an fuel open loop (OL) fault. Now if you do a cold start, it will be in open loop until it warms up. No problems there. However, if you go from open loop to closed loop and back to open loop, and you have a continuous misfire, the PCM is saying it’s having a hard time trying to control fuel and spark so it goes into open loop fault. You have to get to the bottom of this misfire.
Many times it’s a spark issues, but not always. Since you replaced the coil and plugs, double check the connectors and loose wires at the connector. Also check the fuel injector clip and make sure it’s actually seated on the injector. Loose connectors will affect injector operation. This is a cylinder #2 issue so concentrate there. From the looks of it, this is an intermittent issue and will take some patience to find the fault. But the good news is that you know it’s cylinder #2. I honestly don’t think it’s a cat issue because it would be more of a p0300 code and not specific to a cylinder.
Customization is what you want it to look like -- not what other people think it should look like |
#3 | |
Have you tried doing a compression test?
Sorry it's been a minute..... no doing a compression test this weekend. Someone suggested a cam phaser? Something about variable valve timing. This avalanche does have the cylinder drop out for eco mode.
Ok, so did a compression test.
#1) 175 psi. #2) 165 psi #3) 180 psi. #4) 185 psi #5) 185 psi. #6) 190 psi #7) 180 psi. #8) 180 psi So clearly #2 is low, where should I look? Valves? Rings? I'm screwed, I need to get this thing transferred into my name and it's not gonna pass smog.
You can squirt a small amount of oil in #2 cylinder with the spark plug removed. Spin the engine over and see if your compression shows a increase. if it does, then its most likely ring related.
I would guess its carboned rings. If so, buy the GM top end cleaner, pour some in each cylinder and let sit overnight. spin the engine over the next day with the spark plugs out to clear the fluid. Install the spark plugs and go drive the truck to clear out the residue. |
#8 | |
| Bookmarks |
